Sounds like a lifter pecking but isn't! #785400
08/27/10 06:48 AM
08/27/10 06:48 AM
Kentucky
V
vern73 Offline OP
vern73  Offline OP
V
Kentucky
I just freshened my engine and can hear a pecking that is louder than normal and need ideas about what to check. It is a 360 with solid lifters, the rockers are Crane gold shaft mounted, heads are Edelbrock with double springs. I did a normal rebuild with rings and bearings and never touched the heads, I had a broken ring is why I tore it down. So I have adjusted the valves several times and checked all the rockers, then I took off the intake and looked at the lifters and pushrods, fired it back up and the sound is still there. Where should I look next? I need to get this thing back to the track. Maybe some of you have been thru this before. Thanks.
Re: Sounds like a lifter pecking but isn't! [Re: vern73] #785401
08/27/10 07:30 AM
08/27/10 07:30 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline
Vern,
Sounds like a header gasket to me. I had some similar issues haunt me as well, after changing lifters and doing all kinds of diagnostics to end up at a header gasket. Good luck bro.
Don
Street/Strip 73 Barracuda
Re: Sounds like a lifter pecking but isn't! [Re: The Cuda Guy] #785402
08/27/10 08:22 AM
08/27/10 08:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would look at the header gaskets
Re: Sounds like a lifter pecking but isn't! [Re: MR_P_BODY] #785403
09/23/10 06:03 AM
09/23/10 06:03 AM
Kentucky
V
vern73 Offline OP
vern73  Offline OP
V
Kentucky
I found the problem. Hate to say it but I put in a piston backwards so the valves were hitting it. I know I'm getting old but this has to be the dumbest thing I have ever done {to a car anyway} but now it is well along the way to being fixed. Drove me crazy trying to find a problem in the valve train or headers. If you have a similar story about messimg up I'd like to hear one or two to let me know I am not alone.
Re: Sounds like a lifter pecking but isn't! [Re: vern73] #785404
09/23/10 08:33 AM
09/23/10 08:33 AM
MR_P_BODY Offline
MR_P_BODY  Offline
YEARS ago when I was working in a shop a guy was getting
ready to tear off the rockers to correct a ticking
sound and I asked why he was pulling the rockers...
he said well kid what do you think it is.... I grabbed
a screwdriver and pressed on the heat riser and the
noise was gone..... he thanked me and changed it
