Re: -4AN or -3AN?
[Re: SeventyGTX]
#78501
06/22/08 08:58 PM
06/22/08 08:58 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Could someone explain the difference between these two?
Just 2 different sizes... #4 is bigger of course, 1/4" it should be (believe AN = 1/16", or -16 AN is 1" id. from memory..)
Should just check and see what size fitting is on the back of the gauge...and don't forget the AN to pipe thread adaptor for the engine side
Re: -4AN or -3AN?
[Re: SeventyGTX]
#78505
06/22/08 09:08 PM
06/22/08 09:08 PM
OzHemi
Garden Grove, CA
Thanks for the quick response Oz. So, will either one work? I don't have the guage yet, so have no idea the fitting size.
If you are getting the line premaid, really would be good to know what the gauge uses, to save you needing an adaptor.. the adaptor into the block will just be 1/8 NPT (or what ever it is) to the -AN size line you bought
Re: -4AN or -3AN?
[Re: OzHemi]
#78511
06/22/08 10:46 PM
06/22/08 10:46 PM
Posts: 11,881 Fallon, Nv
SeventyGTX
Fallon, Nv
-6 ? Think he measured abit wrong..
Funny thing is, I asked him if he was sure it is that size, and he politely informed me he was a carpenter before he worked for Summit.
Re: -4AN or -3AN?
[Re: SeventyGTX]
#78512
06/22/08 10:51 PM
06/22/08 10:51 PM
OzHemi
Garden Grove, CA
