Page 1 of 4 1 2 3 4
carb hesitaition - squirter or?? UPDATE 9/2 #784816
08/26/10 04:59 PM
08/26/10 04:59 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Hey guys - I had my Challenger to the track for the 1st time at the Mopar Nationals. I only made 2 passes because I was having some carb hesitation. It was mainly breaking up in 1st after I stomped it off the lane, but then it cleared up in 2nd and 3rd. Needless to say my 60ft was less than spectacular (1.68)and the ET wasn't much better (went 11.50 at 118). And it was just too darn hot and humid to care. I just parked it and took in the "show" instead.
So now I'm getting ready to go back to the track locally and hopefully make some clean passes in some nicer weather.
One thing I did try was going from a 33 squirter to a 37. My 2nd pass after the switch was more of the same almost identically. The carb is a quickfuel 950 annular and it does have jet extensions and a 4.5 power valve. Is it possible I need a bigger (than 37) squirter, or perhaps a smaller than 33? The jetting is left as it was on the engine dyno, so I figured it should at least be in the ballpark. Any other suggestions/ideas???
Thanks!
2 kids and a dog
Re: carb hesitaition - squirter or?? [Re: TonyS451] #784817
08/26/10 05:05 PM
08/26/10 05:05 PM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Sounds like the front float level could be to high. If its high when you launch it will come out of the vent tube and splash the carb. Check that. You want to were it is just dribbling out when you shake the car.
Re: carb hesitaition - squirter or?? [Re: Hunted Duck] #784818
08/26/10 05:13 PM
08/26/10 05:13 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
50 or 30cc pump?
Could be the primary pump cam is used up before the mains "kick in" or maybe the secondary shot is too late and the "fat" is buried inthe mains...tough to tell without being there but it's something to maybe consider in terms of tuning.
Could be the float level as Duck said but I'll bet you didn't go to the line without checking that first. You'd probably know if you emptied the bowl and it wouldn't have run what it did.
heavy car big motor/auto/street gears usually wants a lot of shot, I always go with 50's and tune the shooter small rather than run a 30 and "shoot up"
WIZE
In Car:
Re: carb hesitaition - squirter or?? [Re: Streetwize] #784819
08/26/10 07:00 PM
08/26/10 07:00 PM
UK
602heavy Offline
602heavy  Offline
UK
I always run with a tube across bowl vents , eliminates any spill overs.
Re: carb hesitaition - squirter or?? [Re: 602heavy] #784820
08/26/10 07:34 PM
08/26/10 07:34 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I don't know a lot about your combination,but heavy cars without a lot of gear and convertor,seem to need more pump shot than others.At least in my experience.My wife's old street/strip Duster used 42's front and rear at 3370 pounds and 3.91 gears.This was with with a small block,11:90 car.
Basically,I would have someone watch/video the car and see if it puffs a little black on the initial hit or not,and then you know witch way to go.
Re: carb hesitaition - squirter or?? [Re: Dunnuck Racing] #784821
08/26/10 08:05 PM
08/26/10 08:05 PM
SW Missouri
W
willp Offline
willp  Offline
W
SW Missouri
Make sure the front float is not too low also. And the idle mixture is not too lean.
Re: carb hesitaition - squirter or?? [Re: willp] #784822
08/26/10 11:25 PM
08/26/10 11:25 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
my car wants a TON of squirter!!!! 30 degrees if timing under zero boost. I still havent got the hesitation out completly, but im working on it.
I started with 52 squirters and i am all the way up to 78 using a drill bit. I now have to try tightening the accelerator pump arm springs and bending the arm to take up the slop that will cause. If thats not enough I have to open up the squirter circuit to about 89 also with a drill bit
Re: carb hesitaition - squirter or?? [Re: joshking440] #784823
08/27/10 12:23 AM
08/27/10 12:23 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Thanks for all the input. I think I have a pair of 42's and 47's I can try. I'm sure the floats are good and the carb is otherwise in good tune. Btw, I called quickfuel today and they thought the squirter may possibly be too big. Said that sometimes if it squirts too much fuel it can break up or hesitate when it tries to burn/clear up all the fuel. Hmmm, would have never thought that. I have 28's I can try too. I just need to find a low traffic area to do some testing! I want to have the hesitation fixed before going to the track so i can just focus on tuning for power and ET.
Btw Josh, I'm pretty sure you are making a good 500 or so more hp than me, but hope you work your stumble out too
2 kids and a dog
Re: carb hesitaition - squirter or?? [Re: TonyS451] #784824
08/27/10 07:31 AM
08/27/10 07:31 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Tony,
Do you leave off idle or do you bring up the rpms before launch?
If you bring the rpms up, then try the #2 pump cam hole on the primary side. This will delay the activation of the squirt and leave you more later on in the throttle. Then remember to put it back on #1 when you drive home.
Re: carb hesitaition - squirter or?? [Re: YO7_A66] #784825
08/27/10 08:21 AM
08/27/10 08:21 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Can ya post some pics of your challenger??
Re: carb hesitaition - squirter or?? [Re: YO7_A66] #784826
08/27/10 09:54 AM
08/27/10 09:54 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Tony,
I do bring the R's up a little bit before mashing the pedal, but I didn't actually see what RPM I was holding. I know its less than 2k. I will keep your idea in mind, thanks.
Hey Mike - Heres a pic someone took of the Challenger sitting in the pits at the Nats...
2 kids and a dog
Re: carb hesitaition - squirter or?? [Re: YO7_A66] #784827
08/27/10 10:14 AM
08/27/10 10:14 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
pump cam!!
Re: carb hesitaition - squirter or?? [Re: fishy340] #784828
08/27/10 10:48 AM
08/27/10 10:48 AM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
heres another pic of the Challenger...
2 kids and a dog
Carb [Re: TonyS451] #784829
08/27/10 12:31 PM
08/27/10 12:31 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Go with the 'pink' pump cam (no. 1 position) and a #31 pump shooter or squirter.
Re: carb hesitaition - squirter or?? [Re: TonyS451] #784830
08/27/10 12:50 PM
08/27/10 12:50 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
If you set your pump arm clearance at your idle rpms, and then you leave at around 2k rpms, then you have used up some of your accel pumps fuel capacity.
If you test this, remember to reset your pump arm clearance after rotating the cam to position #2.
What color pump cam are you running on the primary?
Re: carb hesitaition - squirter or?? [Re: fishy340] #784831
08/27/10 04:48 PM
08/27/10 04:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
pump cam!!
yep, try a brown or blue cam
Re: carb hesitaition - squirter or?? [Re: YO7_A66] #784832
08/27/10 04:51 PM
08/27/10 04:51 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Honestly, im not 100% sure, but I think its the pink one. Whatever comes standard on a Quickfuel 950 annular. I'll check when I get home later.
2 kids and a dog
Re: carb hesitaition - squirter or?? [Re: TonyS451] #784833
08/27/10 05:00 PM
08/27/10 05:00 PM
Q
Quicktree Offline
Quicktree  Offline
Q
pink wont get the job done. there is a delay from the time you mash the pedal and it starts pumping.
Re: carb hesitaition - squirter or?? [Re: Quicktree] #784834
08/27/10 06:41 PM
08/27/10 06:41 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Use the 50cc pumps, bro and reduce the nozzle size, I don't use a 30cc for anything larger than a 37. a 28 or 31 with a 50 will give you a better overall shot than a 37 with a 30
WIZE
In Car:
Re: carb hesitaition - squirter or?? [Re: Streetwize] #784835
08/27/10 06:46 PM
08/27/10 06:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
but if his air speed is slow I bet he still needs a cam change.
Page 1 of 4 1 2 3 4
