Re: Vacuum guage tune
[Re: gtx69]
#784689
08/26/10 02:05 PM
08/26/10 02:05 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
This is for an auto:
Prior Checks: Timing must be correct first before tuning the carb. Engine off: Check each metering screw to see how many turns outward they are. Then readjust all screws to make them the same. For a reference, add a mark (permanent marker) on the metering screw head at 12:00 on each screw once they are all evenly adjusted.
- Engine must be at normal driving temp (street driven for apx 10-15 minutes). - With engine running, tranny in D, emergency brake applied. - Connect a vacuum gage to the engine and take note on the vacuum reading and the rpm of that vacuum reading. Note: If the vacuum reading fluctuates, take a note on the lowest to highest reading. - Choose a metering screw and turn that one screw outward to the 11:00 o’clock position (reference your mark on the metering screw). - Allow the engine to idle for apx. 20-30 seconds and take note of the new vacuum reading. - If the vacuum reading got higher, then move to the next metering screw and readjust as previously suggested (11:00 o’clock position). If the vacuum reading got lower, then move that metering screw inward to the 1:00 o’clock position (reference your mark on the metering screw). - Allow the engine to idle for apx. 20-30 seconds and take note of the new vacuum reading. - At this time you should be able to determine which direction to turn the metering screws to achieve the highest vacuum reading. Use this sequence on each of the metering screws (2 or 4 metering screws). Once you have adjusted all of the metering screws once as mentioned, then readjust your in-gear idle rpms as required. - I would suggest that this adjusting sequence is done “twice” (two times around the carb) with the car in D to achieve the best in-gear idle vacuum reading. A steady vacuum reading at the preferred in-gear idle rpm should be the goal for a street driven car.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#784690
08/26/10 02:38 PM
08/26/10 02:38 PM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
Cool info, how bout for a manual tranny?
[Re: RapidRobert]
#784692
08/26/10 10:11 PM
08/26/10 10:11 PM
YO7_A66
Indiana
I have a question for the 4 speeders. Since the auto should be tuned against the load (in D), do the 4 speeders (once the N idle is tuned for best vacuum) have to add an additional 1/8 turn outward on the metering screws or do you take care of the best lean idle by adding more pump shot? I am not a 4 speeder but I am curious because I have to turn the primaries outward about an additional 1/10 of a turn from the best NEUTRAL idle settings to get my best in D idle vacuum settings. Thanks!!!!
