Re: 6.1 l hemi
[Re: wireweld]
#783990
08/25/10 05:33 PM
08/25/10 05:33 PM
Posts: 17,914 S.E. Michigan
ZIPPY
S.E. Michigan
600+ hp can be had without any boring, stroking, or porting. Just a little compression, the right cam and a good intake.
Rich H.
Esse Quam Videri
Re: 6.1 l hemi
[Re: rjsjea]
#783992
08/26/10 01:47 PM
08/26/10 01:47 PM
Posts: 37 MI
Jerseyboy
MI
Here you go. This should keep you busy for a while. http://www.shophemi.com/Right now the limit is 440CI with the cast iron block but Mopar has just released an aluminum block that allows you to go out to 468ci. These engines are VERY easy to get power out of. A 600hp 426 or 440 stroker only takes a cam in the mid 230s for duration and is suitable for daily driver duty. Arrington is the biggest name out there but there are others that can build engines on par with them. Lots of good shops on the eastern seaboard (NY/DE/VA/FLA) J
Re: 6.1 l hemi
[Re: Burkenator]
#783994
08/27/10 12:33 AM
08/27/10 12:33 AM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
Not to hijack.....Are there any books out there that show you how to tear one down, torque specs, tips and tricks, etc. to working with one of the new Hemis?
That is what I'm looking for, so far I haven't found anything.
