Re: 2.5 SOHC TURBO LOW OIL PRESSURE??
[Re: 8T2TOP]
#783729
08/27/10 04:54 PM
08/27/10 04:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If he overboosted it and rattled the engine it will hammer the rod bearings and you will have low oil pressure as your first symptom, BTDT. Followed by a rod knock.
[Re: Supercuda]
#783732
08/27/10 08:11 PM
08/27/10 08:11 PM
Posts: 10,958 Oakdale CT
gdonovan
Oakdale CT
I said HAMMERED the rod bearing, not "shot" BTDT.
26 psi of boost with no extra fuel hammered.
When I mean "shot" I mean "pealed right out of the rod"
[Re: gdonovan]
#783733
08/28/10 03:40 AM
08/28/10 03:40 AM
Supercuda
About to go away
About to go away
up yours
paper thin and six inches wide? BTDT, learned a lesson, ALWAYS make sure you remember to hook up the wastegate vacuum line
[Re: stumpy]
#783734
08/28/10 11:50 AM
08/28/10 11:50 AM
Posts: 1,109 Hiram, Georgia
474218
Hiram, Georgia
What is considered "low oil pressure". My 1984 Shop Manual for 2.2 engine states the the "oil pressure switch mininum actuating pressure" is 2 psi.
So at anything over 2 psi the idiot light (if equiped) would be out and the engine would have sufficent oiling?
2 psi is the same for a turbo, EFI, and N/A engine.
