Re: DoctorDiff's rear disc kit
[Re: clovis]
#783718
05/05/11 11:45 PM
05/05/11 11:45 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I remember either Currie or Speedway had a similar kit a couple of years ago at about the same price ($300) but I haven't seen it listed lately on the Speedway site - I haven't looked at Currie's.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: 74_360_Cuda]
#783719
05/05/11 11:53 PM
05/05/11 11:53 PM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
The last posts show my new low cost (bolt-on) 11" GM Metric based rear disc brake kit. It is best suited for drag cars with skinny tires on the front of the car, and large tires on the rear. This brake kit yields more rear bias, as 2", 2 3/8" and 2 1/2" bore calipers are available. Even though they will interchange, I don't recommend using the troublesome GM caliper with the built in parking brake.
I recommend my 10.7" or 11.7", Mustang Cobra based rear disc brake kits for other (street/handling) applications. These kits incorporate a reliable, integral parking brake mechanism and small (1.5") pistons for cars that require less rear brake bias.
[Re: DoctorDiff]
#783720
05/06/11 12:57 PM
05/06/11 12:57 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Too bad about the SVO (Explorer kit) being discontinued. That was a pretty cost effective setup, been a long time since I bought it from you Cass, but I remember it was in the 300 range as well? Works well with the Lokar e-brake cables.
383, Hemi 4-Speed, AlterKtion, D60
[Re: 74_360_Cuda]
#783723
05/07/11 01:51 AM
05/07/11 01:51 AM
Posts: 553 Kentucky
clovis
Kentucky
Do you have stock front end? Booster?
Yes I have the stock front disc that came on my car ('75 Duster), but I do run a '95 Mustang master cylinder.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
