Page 2 of 3 1 2 3
Re: DoctorDiff's rear disc kit [Re: Pale_Roader] #783698
08/31/10 11:49 AM
08/31/10 11:49 AM
AndyF Online content OP
AndyF  Online Content OP
Yes, it is a road race car. Those are 10.7 brakes in the picture and they work just fine on a car that goes 150+ mph. The car could probably use more rear brake so we might step it up to the larger rotors.
Re: DoctorDiff's rear disc kit [Re: AndyF] #783699
08/31/10 11:57 AM
08/31/10 11:57 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
So on a 3200lb E-body with really wide (good) tires the 11.75/11.7" brakes all around would work pretty well at speed...???
Sure wish i could fit the really big stuff under stock rims... I'd like the option ov throwing the stock rims on for a nostalgia night now and then...
Re: DoctorDiff's rear disc kit [Re: Pale_Roader] #783700
08/31/10 01:49 PM
08/31/10 01:49 PM
Just depends how much power you have and how hard you drive. A powerful 3200 lb car that is being driven hard on a road race course will cook the factory 11.75 rotors really quick. If you're just cruising around the track then they'll last a long time.
We use a custom built 13 x 1.250 rotor up front on this Valiant with Baer six piston calipers. Those are $3000 brakes and even those will start to fade after repeated stops from 150. Factory 11.75 rotors up front would be toast in a few laps on a car like this.
Re: DoctorDiff's rear disc kit [Re: AndyF] #783701
09/01/10 07:21 AM
09/01/10 07:21 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
You know, i drive my cars pretty hard. Actually no, i should say i drive them pretty fast, all the time, everywhere, but somehow i am just not hard on the brakes. I get crazy mileage out ov brakes compared to others. Even on the girlfriend's 96GT Mustang, with its 4-wheel (but very small) discs, i've only warped two sets (fronts) in 4 years, and those stock GT (not the Cobra brakes) will warp if you look at 'em hard enough...
I've got a couple cars i've owned for years and years that still have the brakes on them they came with. Sure, road racing will change the needs drastically, but i still say i'd do better than most, wear-wise. Again, the ONLY reason i wont go with bigger 13 or 14" set-ups, is so i can still use stock rims on occasion.
I'm assuming you're doing all the usual tricks with your Valiant like cooling/ducting, SS hoses, etc....??? I haven't gone that far yet, but i will with this project i'm building.
Re: DoctorDiff's rear disc kit [Re: DoctorDiff] #783702
09/05/10 02:46 AM
09/05/10 02:46 AM
Cass, is the Ford Explorer kit still available? Looks like it isn't in the catalog anymore. There is a replacement kit that has a bigger 11.8 rotor and doesn't look the same. The Explorer kit used a drum parking brake and the new M-2300-G2 kit looks like it uses the caliper for the parking brake. Have you used the new kit?
Re: DoctorDiff's rear disc kit [Re: AndyF] #783703
09/05/10 03:08 AM
09/05/10 03:08 AM
Utah
topbrent Offline
topbrent  Offline
Utah
AndyF:
Cass, is the Ford Explorer kit still available? Looks like it isn't in the catalog anymore. Have you used the new kit?
What catalog?
Re: DoctorDiff's rear disc kit [Re: Pale_Roader] #783704
10/01/10 09:52 PM
10/01/10 09:52 PM
los angeles CA, 90015
mikoto Offline
mikoto  Offline
Hi, good day.
there's just had happened to my car and ohh, i just had realized that to increase the boost of my ford i need to fix the engine i mean i need to adjust the settings. from my ford parts. ha ha ha
cheer up!
mikoto | miyata
Re: DoctorDiff's rear disc kit [Re: AndyF] #783705
10/02/10 07:16 AM
10/02/10 07:16 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Alright enough of scaring the kids
Stock rotors hold up under road course conditions at least for me...ok so I only go 130 mph with a old muscle car...I think that is plenty fast. The pads typically give out long before the rotors throw in the towel. I use the wilwood calipers/11.75 rotors with a different pad material that holds up very well under duress[long wearing] and the car stops well without much fade ever. There are air ducts on the rotors as well. I have many miles on this set up, it works, the rotors are wearing nicely and are not warped...I ran for years with the stock stock two piece rotor/calipers with carbon metallic pads, no problems with the rotors, just some fade and poor pad life. [hint it's in the bearing preload]
On another car I have one of Doc Diffs rear wheel disc brakes kits in use and it is a nice set up. We needed a different mounting bracket to clear the firm feel sway bar and Doc Diff came thru with the fix!!!
Re: DoctorDiff's rear disc kit [Re: ThermoQuad] #783706
10/02/10 01:58 PM
10/02/10 01:58 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
No issue with mine. They work great!
Re: DoctorDiff's rear disc kit [Re: gsmopar] #783707
10/02/10 02:42 PM
10/02/10 02:42 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Do these have provision for an emergency brake, also what weight saving is there over 11" drums on my dana.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: DoctorDiff's rear disc kit [Re: AndyF] #783708
10/02/10 05:19 PM
10/02/10 05:19 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Andy,
Yes, Ford discountinued the traditional Explorer rear disc brake kit a few months ago. I think Currie Enterprises is now the oly source for that kit.
I haven't tried the new Motorsport rear disc brake kit.
Deaks,
If I remember correctly, my standard 10.7" rear disc brake kit weighs 21 lbs per side. Parking brake cables are included.
Re: DoctorDiff's rear disc kit [Re: DoctorDiff] #783709
10/03/10 10:03 AM
10/03/10 10:03 AM
K
Kiddart Offline
Kiddart  Offline
K
Doctor Diff do you have a web site to review the kits??
Thank you
Kiddart
Re: DoctorDiff's rear disc kit [Re: Kiddart] #783710
05/02/11 11:42 PM
05/02/11 11:42 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
Re: DoctorDiff's rear disc kit [Re: 74_360_Cuda] #783711
05/03/11 01:09 AM
05/03/11 01:09 AM
His website is in his profile.
Re: DoctorDiff's rear disc kit [Re: AndyF] #783712
05/03/11 02:06 AM
05/03/11 02:06 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, my website is out of date. It does contain links to my eBay listings, which feature the 10.7" rear disc brake kit, however.
www.doctordiff.com
Re: DoctorDiff's rear disc kit [Re: DoctorDiff] #783713
05/05/11 10:26 PM
05/05/11 10:26 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
This is a pretty cost effective solution Cass put together for me. He supplied the re-drilled GM rotors and bolt on brackets. I supplied the GM Metric calipers and line kit. It requires a few little mods on the calipers but overall this is strictly a bolt on upgrade for around $300. You can get the calipers in a 2 3/8 piston, instead of the normal 2 1/2, which with the small 10.5 rotors makes the bias work out good.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: DoctorDiff's rear disc kit [Re: clovis] #783714
05/05/11 10:32 PM
05/05/11 10:32 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
more pics
'75 Plymouth Duster
Re: DoctorDiff's rear disc kit [Re: clovis] #783715
05/05/11 10:39 PM
05/05/11 10:39 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
one more
'75 Plymouth Duster
Re: DoctorDiff's rear disc kit [Re: clovis] #783716
05/05/11 10:58 PM
05/05/11 10:58 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
What is the weight savings over the big Dana drums? I don't know what they weigh.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: DoctorDiff's rear disc kit [Re: clovis] #783717
05/05/11 11:33 PM
05/05/11 11:33 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
Do you have stock front end?
Booster?
Page 2 of 3 1 2 3
