Page 1 of 3 1 2 3
DoctorDiff's rear disc kit #783678
08/25/10 03:52 AM
08/25/10 03:52 AM
AndyF Offline OP
AndyF  Offline OP
I shot a couple of pictures while I had the car up on jacks the other day. This is a really nice disc brake setup that Cass had engineered for the Mopar rear ends. This setup keeps the tapered roller bearings rather than forcing you to switch to the green bearings. It also uses an OEM quality caliper with weather seals and e-brake. Nice setup that is fairly compact and lighweight.
Re: DoctorDiff's rear disc kit [Re: AndyF] #783679
08/25/10 03:55 AM
08/25/10 03:55 AM
AndyF Offline OP
AndyF  Offline OP
Another view, this time without the rotor in the way. The aluminum bracket on this kit is a nice CNC machined part.
Re: DoctorDiff's rear disc kit [Re: AndyF] #783680
08/25/10 08:19 AM
08/25/10 08:19 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I run that kit on my dart! Only difference is I grinded off the ford logo!
Mopar Performance
Re: DoctorDiff's rear disc kit [Re: AndyF] #783681
08/25/10 08:42 AM
08/25/10 08:42 AM
Utah
topbrent Offline
topbrent  Offline
Utah
Which DrDiff rear disk kit is that?
- The caliper brackets shown in your pics look like a 1 piece billet design.
Just curious, as we just purchased the 10.7 rear disk kit from Cass, and it uses a powder coated 2 piece caliper bracket setup.
Re: DoctorDiff's rear disc kit [Re: AndyF] #783682
08/25/10 09:22 AM
08/25/10 09:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Andy what is that arm on the turnbuckle ... I dont
know what I'm seeing
Re: DoctorDiff's rear disc kit [Re: MR_P_BODY] #783683
08/25/10 09:47 AM
08/25/10 09:47 AM
ohio
all spooled up Offline
ohio
sway bar link ???????????
Re: DoctorDiff's rear disc kit [Re: AndyF] #783684
08/25/10 09:53 AM
08/25/10 09:53 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I studied the Fine Lines kit a friend bought that requires the green bearings. I don't see why they say green bearings are required. The Fine Lines kit won't work with factory rally rims, I hear that the kit Cass offers will.
The Dr. Diff kit looks very nice in comparison, which may justify the price difference for some.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: DoctorDiff's rear disc kit [Re: racealittle] #783685
08/25/10 10:27 AM
08/25/10 10:27 AM
Orlando Florida
blown572dart Offline
Orlando Florida
Do they work on a rear with grean bearings?
Re: DoctorDiff's rear disc kit [Re: blown572dart] #783686
08/25/10 11:37 AM
08/25/10 11:37 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
My rear disc brake kits work with OEM adjustable A-7 bearings, 3.15" A-20 tapered bearings, MO-400 Green bearings, ST-400 Green bearings and RP-400 Green bearings.
I have 3 versions with different rotor sizes: 13", 11.7" and 10.7".
The most popular size is 10.7" (pictured) which fits most 15" wheels.
Most 10.7" kits I sell come with a bolt-together steel caliper bracket because the high-offset aluminum version is cost prohibitive.
The 11.7" and 13" versions come with billet aluminum caliper brackets because the offset is much shallower.
Drilled/slotted/plated rotors are optional on all kits.
Re: DoctorDiff's rear disc kit [Re: MR_P_BODY] #783687
08/25/10 11:52 AM
08/25/10 11:52 AM
AndyF Offline OP
AndyF  Offline OP
Adjustable rear anti-sway bar. This is a road race car, not a drag racer.
DoctorDiff's rear disc kit now has been approved at 150 mph!
Re: DoctorDiff's rear disc kit [Re: DoctorDiff] #783688
08/25/10 12:15 PM
08/25/10 12:15 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
Can you run the 13" kit under a 17" wheel or do you need 18s?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: DoctorDiff's rear disc kit [Re: Jerry] #783689
08/25/10 12:26 PM
08/25/10 12:26 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Most 17" wheels will clear my 13" rear kit. This kit is usually paired with 14" or larger front rotors, which won't fit 17" wheels, however.
Re: DoctorDiff's rear disc kit [Re: DoctorDiff] #783690
08/25/10 12:32 PM
08/25/10 12:32 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Do you have a front disk brake kit and if so,whats the cost of it?? I still run drum brakes all around on my 72 duster.
Re: DoctorDiff's rear disc kit [Re: MIKES_DUSTER] #783691
08/27/10 02:30 PM
08/27/10 02:30 PM
GA
roadrunninMark Online sick
roadrunninMark  Online Sick
GA
Another for the doc diff rear kit. I had some questions as well and he was always happy to answer them. Here is a shot of mine installed:
Mark
Re: DoctorDiff's rear disc kit [Re: MIKES_DUSTER] #783692
08/27/10 05:45 PM
08/27/10 05:45 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I also make 11.7" and 13" rear kits as well as matching front disc brake kits with 11.75", 13" and 14.25" rotors.
Re: DoctorDiff's rear disc kit [Re: DoctorDiff] #783693
08/27/10 07:11 PM
08/27/10 07:11 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I love my Dr Diff disc brakes! The combination of parts he recommended on my '68 A-body give nearly perfect balance and modulation. They have saved my bacon a few times in critical finess braking situations. The price is right too!
Re: DoctorDiff's rear disc kit [Re: DoctorDiff] #783694
08/27/10 08:43 PM
08/27/10 08:43 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
These look great.
Can I ask a dumb question??? Well I'm gonna......
If you don't have green bearings and they are required for a brake setup, what can happen? What do you gain? Lose?
Thanks in advance
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: DoctorDiff's rear disc kit [Re: DemonDust] #783695
08/27/10 09:11 PM
08/27/10 09:11 PM
wv
dakster Offline
dakster  Offline
wv
How much width do these rotors add to the rear end, how thick on the rotor hat?
Re: DoctorDiff's rear disc kit [Re: DemonDust] #783696
08/27/10 09:59 PM
08/27/10 09:59 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You can use Green bearings or OEM, A7 tapered wheel bearings with any of my rear kits. Green bearings are not required.
The rotors are .250" thick. This adds 0.125" per side to the original assembly width.
Re: DoctorDiff's rear disc kit [Re: AndyF] #783697
08/31/10 11:38 AM
08/31/10 11:38 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
So this pic is ov a road race car? What size are those rotors in the picture?
Can i assume that the 11.7" rears will fit under stock 15" steel rims? 15x8" Ramcharger rims? How would a 3200lb E-body brake with 11.75/11.7" discs all 'round...???
I've been thinking about this idea for a long time for my 70 Challenger. Last time i checked (long ago) i thought it was AndyF making conversion brakes for Mopars, but now i see his car with Dr. Diff's brakes... Hmmm...
Would the 11.7" rear set-up be lighter than a drum brake set-up?
Page 1 of 3 1 2 3
