Re: Need help,70 Bee C stripe measurements
[Re: JeffsCustomPaint]
#78335
06/22/08 01:35 PM
06/22/08 01:35 PM
Thanks for posting this for me Jeff, hopefully someone will have the answers.
[Re: cdp]
#78337
06/22/08 03:22 PM
06/22/08 03:22 PM
Posts: 3,691 MO
cdp
MO
[Re: cdp]
#78338
06/22/08 03:23 PM
06/22/08 03:23 PM
Posts: 3,691 MO
cdp
MO
#78340
06/22/08 10:09 PM
06/22/08 10:09 PM
Thanks cpd.
What I am mainly looking for is the outside diameter of the circle around the "bee", the width of the smaller stripe, and the total height and width of the thicker part of the "c" around the "bee". If that makes any sense. When I get more time I can edit one of your photos and re-post so you will have a better idea of what I'm looking for.
Any help is appreciated, this doesn't have to be perfect, it going to be for a garage sign/clock. I'm not working on an actual car.
#78341
06/23/08 05:10 PM
06/23/08 05:10 PM
hopefully you can tell what I am looking for from this picture. Just ignore the values that Corel Draw put in for the measurements, they are to scale with the size of the picture. I need the measurements from the real car. Again, thanks for any help you can offer.
#78342
06/25/08 10:44 PM
06/25/08 10:44 PM
#78343
06/28/08 04:52 PM
06/28/08 04:52 PM
#78344
07/02/08 08:44 PM
07/02/08 08:44 PM
Posts: 3,691 MO
cdp
MO
to replicate the corel #s you drew up...
the 5.17" is actually 13.75.
the .070 is acutally 1/8
the 2.40 is 6.50
the 2.20 is 6.0 even
the .51 is 1-5/8"
the distance between the solid part of the decal and the pin strip surrounding is 1/4.
I hope this helps.
