lets talk timing #782623
08/24/10 12:23 PM
08/24/10 12:23 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
New combo. 13.5 to 1 513 based on a rb block with
a set of ported indy heads. What is a good starting
point on timing runing a crank trigger? Is 38 too much?
Thanks Guys.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: lets talk timing [Re: stickman] #782624
08/24/10 01:08 PM
08/24/10 01:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would start at 32 - 34 and work from there .... JMO
Re: lets talk timing [Re: MR_P_BODY] #782625
08/24/10 04:00 PM
08/24/10 04:00 PM
I have on several simialr motors, (700+ HP) both ended up liking no more than 36 degrees on the dyno using race gas BTW, I do verify the timing indicator on the motor with the marks on the balancers to make sure TDC is exactly TDC
Re: lets talk timing [Re: Cab_Burge] #782626
08/24/10 06:41 PM
08/24/10 06:41 PM
imperial mo.
stickman Offline OP
stickman  Offline OP
imperial mo.
Thanks guys. Think I start at 34. get my jetting & shift points close then bump it up see what it likes.
Re: lets talk timing [Re: stickman] #782627
08/24/10 07:15 PM
08/24/10 07:15 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Hery i got kind of a nub question why do people put it all in at 3000 rpms or some other number?
For example:
I've seen 35 degrees all in at 3000, others say 38 degrees all in at 2400 rpms. depe3nding on motor! How does one know?
Mike
1969 Dodge Dart Swinger
Re: lets talk timing [Re: MikeyT] #782628
08/24/10 07:37 PM
08/24/10 07:37 PM
UK
602heavy Offline
602heavy  Offline
UK
Those chambers are gonna be real slooow burning runnin 38* spark lead @ 13.5 CR.
Re: lets talk timing [Re: MikeyT] #782629
08/24/10 08:14 PM
08/24/10 08:14 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
For example:
Mike
That's just a generalization.......Only way to know for sure would be to put it on a dyno.....but, some distributors with really tight springs might not come in until over 4K............
2,400RPM is too low IMHO........I shoot for 3,000 to 3,800, as long as it's all in by the converter stall point (I don't run anything any tighter than 3,800 stall anyway)..........
If you can't handle the truth, you're living a lie.......
