Re: SB strokers carb? [Re: mopar dave] #781666
08/24/10 02:28 PM
08/24/10 02:28 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Just curious how heat range effects A/F ratio, I can see where a hot plug may clean the plug for plug reading but how does it change ratio?
Re: SB strokers carb? [Re: emarine01] #781667
08/24/10 02:34 PM
08/24/10 02:34 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
whats the hotter plug doing? ignighting the mixture early?
Re: SB strokers carb? [Re: ademon] #781668
08/24/10 03:32 PM
08/24/10 03:32 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
25 year old 800 Holley here. On a 416, guessed at the jets/squirters/power valve (none in secondary).
10.33/131 at 3100#.
Oh yea, 1/2 aluminum line to a chrome "dual feed" cheese-ball deal...motor looks like it MIGHT run in the 11's...
Re: SB strokers carb? [Re: cudadoug] #781669
08/24/10 04:24 PM
08/24/10 04:24 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i believe its igniting too early with too hot a plug. you want your air/fuel to have a nice smooth line on the graff. i gained 5hp with the proper plug. i would'nt have believed it if i had'nt seen it with my own eyes. air/fuel looks alittle leaner with hot plug on my graff. i don't have time right now, but i'll post some pics tomorrow if ya want?
Re: SB strokers carb? [Re: cudadoug] #781670
08/24/10 09:43 PM
08/24/10 09:43 PM
owt west
Thread Ender1 Offline
owt west
10.33/131 at 3100#.
Lets see the rest of the car and we will let you know.
Re: SB strokers carb? [Re: Thread Ender1] #781671
08/25/10 01:08 AM
08/25/10 01:08 AM
cudadoug Offline
cudadoug  Offline
It's not much to look at. It's an old leaf spring car built in the mid 80's and kinda/sorta updated over the years. Still has leafs and it's a stock body except the glass hood/deck/bumpers. We think it's a GREAT 60' car...it looks best 60' away!
Don't mean to highjack...back to carb topic!
Re: SB strokers carb? [Re: Voluster] #781672
08/25/10 11:54 AM
08/25/10 11:54 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i'f u wanna buy 1 carb that will get you through most any combo..950hp..i have a 900$ 750hp that was awesome on my 416 barton motor,but couldnt even keep up w my 439sdss motor,,950 would work on both
Re: SB strokers carb? [Re: fishy340] #781673
08/25/10 01:18 PM
08/25/10 01:18 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I do remember an article on Jake King saying if the S&M hemi was a bit rich in jetting he would just use a hotter plug than rejet.
Re: SB strokers carb? [Re: StrokerAspen] #781674
08/25/10 07:13 PM
08/25/10 07:13 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
My friend has a 422 inch stroker with ported/iron W2 heads, TTI 17/8 headers, roller cam which is streetable but rowdy.
We dynoed it with a 750 Holley, A stock 800 cfm Thermoquad, and a brand new OTB Holley 950. The 950 made the most power by 20 HP over the others, 525HP/510TQ.
Re: SB strokers carb? [Re: ScottSmith_Harms] #781675
08/26/10 01:08 AM
08/26/10 01:08 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
ive got a holley 950HP no pvs fwiw
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: SB strokers carb? [Re: Stroker Scamp] #781676
08/26/10 09:50 AM
08/26/10 09:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have gone quicker and faster with every carb increase...
I started with a 750 on a smaller engine then stepped
up to a 396ci... I started with a 750 on that one then
went to a 850, 950 and finally a 1050 dom... if I had
a 1150 I would try that also..... BUT I launch off a
trans brake and that makes some difference... I dont
need the real fast low end response (mines pretty darn
good) but the smaller carbs will be a little faster
on the low end response
Re: SB strokers carb? [Re: MR_P_BODY] #781677
08/28/10 10:04 PM
08/28/10 10:04 PM
Ma
Voluster Offline OP
Voluster  Offline OP
Ma
no Vacuum leak found on my car today
we hit all around the carb with carb cleaner and all the intake ports.
then put a rag over the carb and it stalled out once you put pressure on it
what else do you thing it could be?
besides to small of carb
thanks Phil
Re: SB strokers carb? [Re: Voluster] #781678
08/28/10 10:14 PM
08/28/10 10:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks Phil
When I'm doing what you did with the rag I do that
with my hands so I have a idea how much air is going
in... if its not blowing smoke out of the pipes(oil)
from under the intake then you might have a internal
air leak in the carb... have you torn it down and
checked the gaskets... it sounds like its lean if
you had to press down on the rag... borrow a carb
and try another one... any size that fits...JMO
Re: SB strokers carb? [Re: MR_P_BODY] #781679
08/28/10 10:30 PM
08/28/10 10:30 PM
Ma
Voluster Offline OP
Voluster  Offline OP
Ma
No oil in the chambers at all all the plugs come out dry. it's not smoking at all.
I have a 850 demon I'm gonna try off a buddies motor
