What does everyone seem to be running for a carb on their SB stroker?
I have a bigs stage 5 750 on there now
I ran the car at the track this weekend and it ran 7.17 at 94 mph in the 1/8 off the trailer. got worse as the day went on track went away and air got worse. lost 2 10ths in just the 60 after the 1st run
When I got back to the pits pulled some plugs these things had no color on them at all. I started jeeting it up throughout the day. I went up 13 jets from where I was at the start of the day and it just started getting some color on the plugs.
Was just trying to get an idea of what everyone else is running for a carb on thier strokers.
Mine is a 416 with eddy heads 600 lift solid cam m1 intake 727 8 inch conveter 3.91s in the 8 3/4 275 drag radial
