I was running the valves on our Hemi yesterday when I noticed the #4 Intake Push Rod was bent pretty bad.
I also noticed that most of the intake push rods are bent slightly.... more distorted then bent, I'm not sure if that's normal or not.
I know that push rods are like spaghetti flapping around when the motor is at RPM, so I wold have to assume that they would have distort some what.
But what would cause the #4 bending, fatigue? or should I be looking for something else?
The motor goes through around 7500 RPM. Were running a 780 lift Roller.
We probably have 70-80 passes on it.
Kevin
