Re: Koleno blocks
[Re: rebel]
#780922
08/23/10 08:32 AM
08/23/10 08:32 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
are they going to produce a low deck? big bear was looking for feedback a while ago but never heard the outcome.
Re: Koleno blocks
[Re: Diablo]
#780924
08/23/10 05:04 PM
08/23/10 05:04 PM
Posts: 622 sing sing
unknown
sing sing
Haven't used one but if they had what i needed (4.480 BS) they would have got my money! Everything i've heard so far has been great! And Big Bear (moparts member) is a great guy to talk to!
4.840 bs
Re: Koleno blocks
[Re: fury62]
#780926
08/23/10 05:15 PM
08/23/10 05:15 PM
Posts: 627 IN
BIG BEAR
IN
I'm using one built by best machine.no problems looks like a mopar RB block. 540inch w/indy sr head, m1 intake, quick fuel 1050 made 695hp @6500 call chuck at best machine
Re: Koleno blocks
[Re: unknown]
#780927
08/23/10 05:21 PM
08/23/10 05:21 PM
Posts: 1,106 Quebec, Canada
Diablo
Quebec, Canada
4.840 bs
A block that will except the heads with a 4.840 bore spacing. The B1-Ts heads i run are for a bigger bore spacing. Allows for a bigger bore, heads and mine is a taller deck then stock also. Helping with skirt wear when stroking it five inches
Re: Koleno blocks
[Re: racerx]
#780930
08/23/10 06:37 PM
08/23/10 06:37 PM
Posts: 627 IN
BIG BEAR
IN
Like to hear more info on these blocks. is there a possible release date on these? Thaxx..
It will be very very similar to the kp440 only shorter deck and will also use the 400 distributor. I'm sorry that I can't give you a release date yet. We will still need to build a small inventory and with roush machining them its hard to get any exact dates.
Diablo- don't worry your day will come
Re: Koleno blocks
[Re: blownzoom440]
#780934
08/24/10 11:33 AM
08/24/10 11:33 AM
Posts: 1,449 Commerce, Michigan
EasyG
Commerce, Michigan
i have a KP 440 RB and made 1150HP on the dyno.just bored to 4.350 with 3.75 stroke.factory iron heads[346]2x1250 carbs and 15 lbs of boost on 112 fuel.track time yet to come.
With those kind of numbers you should come up to Milan on one of the heads up Friday night events and show the Outlaw Class what ya got! All that HP out of some 346's, that's awsome! Just think what could be if you turned the wick up on the boost!!!
Re: Koleno blocks
[Re: blownzoom440]
#780936
08/24/10 05:51 PM
08/24/10 05:51 PM
Posts: 976 ontario canada
mac56
ontario canada
Wow is all I can say
