Vehicle Build Date #780786
08/22/10 09:36 PM
08/22/10 09:36 PM
Central Texas
71R/T Offline OP
71R/T  Offline OP
Central Texas
The build date for my 1971 Dodge is listed on the fender tag as Dec 11 1970, but the VIN decal on the door reads 1-71 as the build date. Is it normal for these dates to be different or does it depend on the assembly plant or which part of the year a car was built?
Re: Vehicle Build Date [Re: 71R/T] #780787
08/22/10 09:41 PM
08/22/10 09:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The date on the fender tag / broadcast sheet is the Scheduled Production Date - not the actual build date unless it is just a coincidence.
The SPD is the date they hoped to build the car when the order first hit the system.
Your car was built later than the SPD for some reason.
See this thread for more info;
https://board.moparts.org/ubbthreads/show...e=0&fpart=1
Re: Vehicle Build Date [Re: Alaskan_TA] #780788
08/22/10 09:43 PM
08/22/10 09:43 PM
Central Texas
71R/T Offline OP
71R/T  Offline OP
Central Texas
Is that uncommon or something that simply happens from time to time?
Re: Vehicle Build Date [Re: 71R/T] #780789
08/22/10 09:49 PM
08/22/10 09:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
VERY common.
Some cars were late & will have the door sticker dated the next month.
Some were built early & will show the prior month.
Re: Vehicle Build Date [Re: Alaskan_TA] #780790
08/22/10 11:01 PM
08/22/10 11:01 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
71R/T is this a Challenger you are talking about.
1971 HEMI E BODY REGISTRY
Re: Vehicle Build Date [Re: hemicar1971] #780791
08/23/10 08:30 PM
08/23/10 08:30 PM
Central Texas
71R/T Offline OP
71R/T  Offline OP
Central Texas
It's a Charger R/T.
