Re: B1-BS Spark Plugs ????
[Re: mrplymouth]
#780354
08/22/10 04:29 PM
08/22/10 04:29 PM
Posts: 23 Mt Hope Ontario Canada
B1DartGT
Can't help you with the peanut plug deal.... but I always found the colder plugs would foul on me while street driving. My motor was slightly above 11-1 complession and anything colder than about a 4 or 5 heat range in an NGK, the car would start popping while street driving. I never saw any performance change at the track, just on the road. Always thought it could be because I'm using a dominator and need the extra heat to burn the fuel at lower RPM??? You're right... I've got the same heads in a Dart and plug changes are a huge pain.
Good judgement comes from experience, and a lot of that comes from bad judgement.
