True it should be close to middle.
Did you add any accessories like electric fans, high amp stereo, or other power accessories? If so they should be between the Alternator and the ammeter not between the ammeter and the battery. If they are hooked up to the battery side then the alternator is powering them through the ammeter and it will read charging all the time.
First make sure the ammeter is working semi-correctly.
Ignition off should be at center. Hit the brakes it should drop to below center. Turn on headlights on also and it should drop farther.
If it isn't reacting correctly it could be the ammeter.
Next charge the battery completely off the car and test it. When you start the car it should be near center.
If not and the added accessories are on the alternator side of the ammeter it is probably the voltage regulator overcharging. A VR overcharging can kill the wiring harness just like a short can. Test the Alternator and replace the VR.
Hope it helps.
