Re: Floor shift kit for push button 727?
[Re: TooMany62s]
#780129
08/22/10 11:46 AM
08/22/10 11:46 AM
Posts: 2,590 Piqua, Ohio
dodgeram440
Piqua, Ohio
The 65's still used a push button shifter on the base models, although some models did use a floor shifter also. The transmission is still cable shifted with both style shifters.
The early transmissions used two cables from the shifter, one for the park mechanism and one for the gear selection. If you intend to keep your original transmission, you need a floor shifter from one of those models for everything to work correctly.
The 65 Coronet 500 I once had had the floor shifter with the console. The shifter was actually mounted to the console instead of the floor. The shifter had two cables, one went to the normal gear selector position on the tranny, the other cable went to the back of the case itself, not the tailhousing, to operate the park mechanism.
Hope this helps.
[Re: dodgeram440]
#780130
08/22/10 01:52 PM
08/22/10 01:52 PM
Posts: 1,803 Greer, SC
TooMany62s
Greer, SC
Base models in '65 had column shift. It's what makes the '65 column shift steering columns unique. One year only. No push buttons in '65.
[Re: dodgeram440]
#780131
08/22/10 02:33 PM
08/22/10 02:33 PM
RapidRobert
My 65 dart w a floor console shifter had the 2 cables. I was thinking there weren't any pushbuttons after 64??
[Re: TooMany62s]
#780132
08/22/10 03:18 PM
08/22/10 03:18 PM
dodgeram440
Piqua, Ohio
Maybe I'm wrong about that. Fine, I will be the first to admit that I don't know everything. I just seem to remember that my first 65 Coronet 2 door post car had the push buttons in the dash, although it was replaced by the floor shifter that had been installed by the previous owner. Of course that was 20 yrs ago, and with no pictures of the interior, it's kind of hard to confirm.
However, in helping the OP, if he gets a shifter and console from one of these cars, he can have a floor shifter and still retain his stock two cable transmission.
[Re: dodgeram440]
#780133
08/22/10 03:55 PM
08/22/10 03:55 PM
Posts: 27,334 Rio Linda, CA
John_Kunkel
The Erection Connection
Rio Linda, CA
No pushbuttons after '64.
In order to make the '64-'65 console shifter work with a PB transmission the valve body needs to be changed.
[Re: John_Kunkel]
#780138
08/22/10 05:51 PM
08/22/10 05:51 PM
dodgeram440
Piqua, Ohio
Why does the valve body need to be changed? The 65 tranny is still cable operated, whether or not it was push button or lever. In either case, there is still two cables to the system, one for gear selection and one for park.
[Re: dodgeram440]
#780139
08/22/10 05:55 PM
08/22/10 05:55 PM
John_Kunkel
Rio Linda, CA
The '64 console/'65 VB casting is bored for and has an extra notch for Park. If you install a '64-'65 console shifter on a PB trans the manual valve will bottom out before reaching the Park position.
[Re: dodgeram440]
#780141
08/22/10 06:31 PM
08/22/10 06:31 PM
Posts: 2,431 USA
SSAAHemiFan
USA
I sold a Art Carr "nifty shifter" a few years back. At that time he said he was thinking of making another small batch , But they haven't surfaced yet that I am aware of He said he used the mechanism / buttons for these shifter's from either a 60's dodge truck (sweptline?) or A-100.
