Re: 68 RR hood
[Re: rc68rr]
#780100
08/22/10 02:11 AM
08/22/10 02:11 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Like this? This is another members car, not mine.
Re: 68 RR hood
[Re: 68jim]
#780103
08/22/10 11:42 AM
08/22/10 11:42 AM
Posts: 3,407 S.E. Florida, USA
rrunner
S.E. Florida, USA
Gots lots of pictures...what are you looking for specifically?
Would help if we knew what it is you are looking for.
Re: 68 RR hood
[Re: rc68rr]
#780106
08/22/10 01:05 PM
08/22/10 01:05 PM
rrunner
S.E. Florida, USA
Sorry about that, I would like to see some pictures of both sides & where the inserts are. Ours has a 383 in it but the hood has hemi inserts. I am not sure if it's a 68 or 69 hood we have. Thanks
OK, There are two 68 hoods, early to mid and mid to late. The skins are the same, it's the under structure that differs. All 68 hoods that I have ever seen even into the last days of production are soild under the bolt in insert. 69's had four areas cut out under the insert for the air grabber option. Here's a early to mid 68 hood
Re: 68 RR hood
[Re: Donny]
#780110
08/22/10 01:26 PM
08/22/10 01:26 PM
rrunner
S.E. Florida, USA
Is it me or does that look strange, it is an optical illusion from the angle in which you took the picture?
Looks fine to me. Also from the pic's I've seen of the resto, there's NO problem there!
