Need help with Tranny fluid in a 727??? #780053
08/21/10 11:45 PM
08/21/10 11:45 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
I drained the fluid to install a new locking dip stick in my TF 727 with 8" converter. It has a deep pan not stock. Specs say a stock 727 takes 9qts. I got 4 quarts in it and it started backing up the dip stick tube. I fired it up to get it warm and get it into the converter etc and I then added more but it still kept trying to back up the tube. I have 6 1/2 quarts in it but it keeps backing out the dip stick tube after I warmed it up a few times. It seems way over filled. Any chance the converter would keep 4 quarts in it while I drained the pan? I'm thinking about siphoning it out until it's correct on the dip stick tomorrow Worried I'll be low on fluid and hurt the tranny. What could happen with having too much fluid and running it? Any ideas, I'm open for suggestions. I'm stumped. Thanks
Re: Need help with Tranny fluid in a 727??? [Re: Big_Fish] #780054
08/21/10 11:53 PM
08/21/10 11:53 PM
florida/ Georgia
Tom Fox Offline
Tom Fox  Offline
florida/ Georgia
if you only drained the pain of its fluid, then thats all you need to replace, maybe 4 qts or less.
Re: Need help with Tranny fluid in a 727??? [Re: Big_Fish] #780055
08/21/10 11:54 PM
08/21/10 11:54 PM
If you didn't(couldn't) drain the converter I think 6 quarts is enough, are you checking the fluid level in neutral with the motor running? IF not try that before draing anymore out of it. I run my trans with the Mopar deep steel pans at the add mark warm or below the add mark cold
Re: Need help with Tranny fluid in a 727??? [Re: Cab_Burge] #780056
08/22/10 12:01 AM
08/22/10 12:01 AM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Sounds like I over filled it, damn. With 6qts it backed up the tube. I ran it and got it nice and hot and then went to check it again and it puked all over as soon as I pulled the dip stick. Sounds like I'm at least 2qts over. Wonder if siphoning will be easier than removing the tranny blanket and dumping some out of the pan at this point. I feel like a real jack ass. ThanX for the dip stick reference and quart reference.
Re: Need help with Tranny fluid in a 727??? [Re: Big_Fish] #780057
08/22/10 12:44 AM
08/22/10 12:44 AM
Az
Crizila Offline
Crizila  Offline
Az
I know with a stock 727 pan, the stick reads full with 3 qts - cause I just did it.
Fastest 300
Re: Need help with Tranny fluid in a 727??? [Re: Crizila] #780058
08/22/10 01:09 AM
08/22/10 01:09 AM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
I have an older steel deep pan so I think 3 or 4 quarts was what I should have added.
Re: Need help with Tranny fluid in a 727??? [Re: Big_Fish] #780059
08/22/10 02:49 AM
08/22/10 02:49 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
9 quarts would be right with a fresh transmission and converter. Just dropping the pan will get less than half the oil out.
Re: Need help with Tranny fluid in a 727??? [Re: CMcAllister] #780060
08/22/10 09:29 AM
08/22/10 09:29 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I've had an air lock before and it would a ton of fluid all over the garage celing and wall when I shut it off
Looking back on it now I can but at the time I was
New trans and vert @ the time, called the place that sold it to me for help, they were no help.
Ended up cracking loose the return line on my fluid cooler to let the traped air escape, B I N G O
Never had this happen before & hasn't happened since
Maybe worth just my wierd experience and worth.
Re: Need help with Tranny fluid in a 727??? [Re: roadhazard] #780061
08/22/10 11:19 PM
08/22/10 11:19 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Hmmm I may just try this to see if I do have any trapped air because my gut feeling was that it was pressurizing. Can't hurt, thanX for the input roadhazard.
Re: Need help with Tranny fluid in a 727??? [Re: Big_Fish] #780062
08/23/10 12:18 AM
08/23/10 12:18 AM
San Clemente, ca
enelson Offline
mopar addict
enelson  Offline
mopar addict
San Clemente, ca
yea if in doubt don't overfill but check lots I've not had the issues with air locks before but try to prefill/lube the crap outta everything and sneak up on it...
Re: Need help with Tranny fluid in a 727??? [Re: Big_Fish] #780063
08/23/10 12:33 AM
08/23/10 12:33 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I was told by one of the trans builders to start it in neutral instead of park so it would pump all of the air out of it.
I don't know what difference it would make, maybe he was just having a laugh at my expense.
Old Geezer Racing
