Tach Question #779923
08/21/10 08:47 PM
08/21/10 08:47 PM
PA
dumbdog70 Offline OP
PA
Just got a new Sunpro Super TachIII installed it today. Four wires straight forward easy hookup but it does not work. When i start the car tach reads 2500 and when you rev the engine tach wont go past 4000. those readings are inaccurate. Im running a Mallory 6AL ignition. Of course their tech line is closed. Am I overlooking something? Wires are black=grounnd white=lights red=hot w/ign on green=tach wire on ign box
Re: Tach Question [Re: dumbdog70] #779924
08/21/10 09:04 PM
08/21/10 09:04 PM
Under My Car
Mopar_Country Offline
Under My Car
You may need an 8920 adapter, has something to do with the voltage.
You might find help here:
http://www.msdignition.com/forum/
Re: Tach Question [Re: Mopar_Country] #779925
08/22/10 07:02 PM
08/22/10 07:02 PM
Lebanon, TN
bronzegtx Offline
bronzegtx  Offline
Lebanon, TN
Do you have it set to 8 cyl? If it is on 4 or 6 cyl it will also do that. The setting is on the back of tach.
