Page 3 of 4 1 2 3 4
Re: "It Could Be Worse!" [Re: Hunted Duck] #779394
08/22/10 11:14 PM
08/22/10 11:14 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
What is your next move, as in replacements?
Re: "It Could Be Worse!" [Re: Leigh] #779395
08/22/10 11:51 PM
08/22/10 11:51 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
And you said that you had no luck...get it fixed and back out there!
Re: "It Could Be Worse!" [Re: S/ST 3040] #779396
08/23/10 12:22 AM
08/23/10 12:22 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
As posted earlier, parts were not aluminum. I didn't mean for this to be
a "vendor bash". I am just extremely thankful I didn't crash the car.
Whats More Important! "IS"
Is, to let people know that may be using these same steering arms is, that they may have some weak design flaw issues. I dont care who the vendor is. Its not about the "Vendor"
Its about a Weak design flaw, As is,IMO and from your own experience. I would want every possible Moparts user of same said parts to "Beware" and check for the same said structure cracks for their own safety.
I will add that the part as is could be reinforced to work safely, IMO. But taking fatigue into consideration, maybe it would be best to start from scratch/new. mike
Re: "It Could Be Worse!" [Re: Sport440] #779397
08/23/10 08:40 AM
08/23/10 08:40 AM
On the south side of Nowhere
S/ST 3040 Offline OP
Very good point Mike. As a matter of fact, my car has had an inherent
front end vibration that very well could have unduely stressed these
arms and expidited their breaking. I advise anybody using these to
take the time to thoroughly inspect their steering arms for cracks, etc.
Leigh, I am undecided on the method of repair or replacement.
Re: "It Could Be Worse!" [Re: S/ST 3040] #779398
08/23/10 09:01 AM
08/23/10 09:01 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I'm glad you caught this before it turned real bad.
Re: "It Could Be Worse!" [Re: HardcoreB] #779399
08/23/10 09:12 AM
08/23/10 09:12 AM
Thanks. Every time I see somebody roll their car, scrape the
wall or shear off wheel studs and ruin a quarter, it makes me
sick. I know first hand, how much you can get wrapped up in
a drag car (monetarily, emotionally, time)
I'm thankful, I wasn't one of them Friday night.
Re: "It Could Be Worse!" [Re: S/ST 3040] #779400
09/01/10 09:04 PM
09/01/10 09:04 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
is it fixed yet
come on let's get
Re: "It Could Be Worse!" [Re: S/ST 3040] #779401
09/01/10 09:14 PM
09/01/10 09:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
OR and more likely... the weak design COULD have
been the vibration (wheels moving back and forth)
Re: "It Could Be Worse!" [Re: Mrs.Hitman] #779402
09/01/10 09:29 PM
09/01/10 09:29 PM
gregsdart Offline
gregsdart  Offline
In the interest of safety, get some stock parts modified to work. The extra 1/2 pound is well worth it! These arms were cut off and welded back on at the right height and length.
They have proven to be extremely durable.
Re: "It Could Be Worse!" [Re: gregsdart] #779403
09/01/10 09:47 PM
09/01/10 09:47 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
or get lucky and just use a stock lower ball joint arm installed on the opposite side with no cutting and just a little bending
home of the
Sox and Martin Hemi Duster
Re: "It Could Be Worse!" [Re: HEMIFRED] #779404
09/01/10 10:33 PM
09/01/10 10:33 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
or put a set of billet ones on
Re: "It Could Be Worse!" [Re: HEMIFRED] #779405
09/01/10 11:21 PM
09/01/10 11:21 PM
Arizona
Chris'sBarracuda Offline
Arizona
That's exactly the way mine has been for 18 years now.
And it wheel stands quite a bit.
Chris..
Re: "It Could Be Worse!" [Re: HEMIFRED] #779406
09/02/10 09:20 AM
09/02/10 09:20 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I thought you were not supposed to heat front end components?
Re: "It Could Be Worse!" ADVISORY [Re: S/ST 3040] #779407
09/08/10 03:08 PM
09/08/10 03:08 PM
I got my pictures loaded on to the computer for some side by side shots.
I want to thank Bondo Bob for building me a pair of billet 7075 arms to
get me back to racing. I still have some bump-steer to correct but, no
vibration my last time out. So, visions of barrel-rolling down the track
won't affect my concentration.
Re: "It Could Be Worse!" ADVISORY [Re: S/ST 3040] #779408
09/08/10 03:11 PM
09/08/10 03:11 PM
2
Re: "It Could Be Worse!" ADVISORY [Re: S/ST 3040] #779409
09/08/10 03:22 PM
09/08/10 03:22 PM
I had to do a little trimming to my OEM lower control arms.
Re: "It Could Be Worse!" ADVISORY [Re: S/ST 3040] #779410
09/08/10 03:33 PM
09/08/10 03:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Boy some of our members do some beautiful work. I'm glad their on our side.(mopar or no car)
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: "It Could Be Worse!" ADVISORY [Re: S/ST 3040] #779411
09/08/10 04:31 PM
09/08/10 04:31 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
If aluminum, the car manufacturers use forged aluminum steering parts, probably for the grain flow and fatigue strength.
If "steel" parts are made of steel forgings, they can be heated and bent without too much strength reduction, but if heat treated cast iron (aduser-ferrous) or nodular iron is used, it is advised not to heat, bend, weld or alter the shape of the piece. For drag-racing anything is done, but the safety factor is challenged every time. Maybe you are "better safe than sorry".
Thanks.
Re: "It Could Be Worse!" ADVISORY [Re: S/ST 3040] #779412
09/08/10 08:36 PM
09/08/10 08:36 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Glad to hear you have it back together and racing again. That Bondo, whatta' guy.
Re: "It Could Be Worse!" [Re: Mrs.Hitman] #779413
01/02/11 10:21 PM
01/02/11 10:21 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Last Pic.
whos stuff was that?
Mopar Performance
Page 3 of 4 1 2 3 4
