Page 1 of 4 1 2 3 4
"It Could Be Worse!" ADVISORY #779354
08/21/10 02:22 AM
08/21/10 02:22 AM
On the south side of Nowhere
S/ST 3040 Offline OP
I get so sick of hearing that. This time I have to agree.
We took the car up to US-131 for Friday Test & Tune after
I fixed a leaking head last week. 1st pass off the trailer car
goes 9.9804 @ 130.9 MPH and I catch some flack picking
up my slip from the ET shack for not having a license. We're
there testing air pressures and shock setting for 60 ft. times
anyway so I start clicking it off at the 1000'
Burnout for the 3rd pass felt "weird".........I stage the car
and lift at the 1000' cone. Coming back the return road, I
notice my steering wheel is crooked. I knew immediately
something was wrong. Something was.
I was doing 123 MPH when I lifted. It could have been worse.
Anybody using this style of steering arm......Please inspect them thoroughly for cracks, etc.
Re: "It Could Be Worse!" [Re: S/ST 3040] #779355
08/21/10 02:25 AM
08/21/10 02:25 AM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
That could have gotten real ugly!!
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: "It Could Be Worse!" [Re: S/ST 3040] #779356
08/21/10 02:28 AM
08/21/10 02:28 AM
Re: "It Could Be Worse!" [Re: S/ST 3040] #779357
08/21/10 02:31 AM
08/21/10 02:31 AM
Somebody loves you, He is looking after you
Re: "It Could Be Worse!" [Re: S/ST 3040] #779358
08/21/10 02:35 AM
08/21/10 02:35 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed............you are one lucky man.
Re: "It Could Be Worse!" [Re: Cab_Burge] #779359
08/21/10 02:35 AM
08/21/10 02:35 AM
I have to agree again. It's been a long day and another on
it's way.
I'll miss the $2000 race tomorrow but, can make my home
track Sunday. I have to get up early.
Re: "It Could Be Worse!" [Re: S/ST 3040] #779360
08/21/10 08:39 AM
08/21/10 08:39 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
You dodged a bullet there.
IMO, Putting flimsy little pieces in your steering is nuts. Especially since it looks to be aluminum.
Re: "It Could Be Worse!" [Re: S/ST 3040] #779361
08/21/10 09:07 AM
08/21/10 09:07 AM
NC
440Jim Offline
440Jim  Offline
NC
Good to hear you didn't crash, it could have been worse. LOL
What brand parts are those?
How many passes are on them? (ie age, use)
Curious what your car weighs.
Re: "It Could Be Worse!" [Re: 440Jim] #779362
08/21/10 09:15 AM
08/21/10 09:15 AM
tboomer Online work
tboomer  Online Work
Wow!! You really dodged a bullet on that one..
Re: "It Could Be Worse!" [Re: tboomer] #779363
08/21/10 09:28 AM
08/21/10 09:28 AM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Is that steering arm a part that a manufacturer is selling?
It is not strong enough for the application.
Kinda scary.......
Re: "It Could Be Worse!" [Re: S/ST 3040] #779364
08/21/10 09:43 AM
08/21/10 09:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Vic did you hit something to do that
Re: "It Could Be Worse!" [Re: MR_P_BODY] #779365
08/21/10 09:53 AM
08/21/10 09:53 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
glad your safe and didnt get hurt...
Mopar Performance
Re: "It Could Be Worse!" [Re: moparniac] #779366
08/21/10 10:02 AM
08/21/10 10:02 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
wow, you got lucky....that's the good thing. Who's parts are those?
Re: "It Could Be Worse!" [Re: S/ST 3040] #779367
08/21/10 10:21 AM
08/21/10 10:21 AM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
that was close..
Re: "It Could Be Worse!" [Re: dc426] #779368
08/21/10 10:43 AM
08/21/10 10:43 AM
ohio
all spooled up Offline
ohio
hint land of lincoln
Re: "It Could Be Worse!" [Re: S/ST 3040] #779369
08/21/10 11:38 AM
08/21/10 11:38 AM
Louisville, MS
Dustedu Offline
Dustedu  Offline
Louisville, MS
Re: "It Could Be Worse!" [Re: PUNK] #779370
08/21/10 12:19 PM
08/21/10 12:19 PM
BPE Offline
BPE  Offline
Just had breakfast with Vic, he is over at Jeff Allison's shop getiing it fixed. Just glad that's all that happened, he was lucky for sure.
Rod
Re: "It Could Be Worse!" [Re: BPE] #779371
08/21/10 12:35 PM
08/21/10 12:35 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
So much for doing wheelstands,......
Re: "It Could Be Worse!" [Re: S/ST 3040] #779372
08/21/10 12:56 PM
08/21/10 12:56 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
The steering arm extention is plenty strong, but its attachment point to the spindle is Extremely weak!!
Is that what?? about 1/8 to 3/16,s thick Id want a 1/2" minimum.
Both of those steering arms need to be replaced with stronger, smarter versions before Id run that car again. Somebody focused on the strength of the steering arm extention and not its attachment points. Im sure they know that now, Get her fixed Vic! Im glad you missed the bullet on that one , mike
Re: "It Could Be Worse!" [Re: Sport440] #779373
08/21/10 05:53 PM
08/21/10 05:53 PM
Well, not going as planned. After complete disassembly of both
sides, it appears I was closer to disaster than I'd first thought.
The rear mount on the same side has cracks in that area all the
way around. It would not have held the car up one more pass.
The right side was cracked completely around the front mount
and about half way on the rear. I'm not going to make any further
attempt to fix, repair or otherwise try and use these again.
I forgot my camera but, took a few pictures with Jeff's. Maybe he will post them later.
I bought this front end used (LRT) and have no way of knowing it's age or
number of passes. I did not hit anything with the car. Weighs 2622 lbs.
Page 1 of 4 1 2 3 4
