Factory paint in 1964? #779202
08/20/10 09:34 PM
08/20/10 09:34 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
What type of paint was standard on a 1964 Fury? Thanks!
Re: Factory paint in 1964? [Re: polkat] #779203
08/20/10 09:47 PM
08/20/10 09:47 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
Laquer most likely. Might have been nitro cellulose laquer. I'm not sure when they stopped using that. Maybe an old timer will chime in....if they can remember that far back
Re: Factory paint in 1964? [Re: AeroMonte] #779204
08/20/10 11:47 PM
08/20/10 11:47 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
acrylic enamel
Re: Factory paint in 1964? [Re: polkat] #779205
08/21/10 12:10 AM
08/21/10 12:10 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Lacquer was for GM's. Enamel for that 64.
Sheldon
Re: Factory paint in 1964? [Re: RUNCHARGER] #779206
08/21/10 01:32 AM
08/21/10 01:32 AM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
So we agree that it was enamel...or acrylic enamel? Is there a difference?
The paint on the car is an original dark brown and is quite clean. I want red and am not very particular about quality. So if I can find the same kind of paint, I can skuff the original and use it as a primer.
Would any enamel work?
Re: Factory paint in 1964? [Re: polkat] #779207
08/21/10 04:30 PM
08/21/10 04:30 PM
MO
cdp Offline
cdp  Offline
MO
I think it would be wise to use a primer/sealer regardless. Its allot of work to prep paint only to see it peal off a short while later.
Chrysler used acrylic enamel starting sometime in the early 60's,....61-62 or if I remember right.
you could check out TCPglobal for a reasonble priced paint or I hear even Summit Racing even sells paint now.
