Re: HEI module...
[Re: kilroy]
#779126
08/30/10 01:20 PM
08/30/10 01:20 PM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
Can someone explain the ohms need on a coil? there is a .25, .5, and 1.5. I would like to use one of the hot ecoils but I dont understand which ohm I should use. Im using electronic ignition w/ chrome box.
You can use the late model coils, for example, a coil for a 92 dodge truck would work perfectly, and would eliminate the ballast
Re: HEI module...
[Re: 70duster340]
#779127
08/30/10 01:24 PM
08/30/10 01:24 PM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
Can anybody advise of any brackets that may be available for the e-core coil to be mounted in the stock location?
You'll have to get a E-core coil bracket and then modify it
I am in the middle of doing this swap today....will post pics
Re: HEI module...*updated, done!*
[Re: '84 D150 Shorty]
#779129
08/31/10 10:21 AM
08/31/10 10:21 AM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
OK folks, its now (for me) no longer a can it be done topic, but a "i dunnit" topic lol. After several hours of painstaking work, The truck is running on the HEI module....and let me say, wow. I wasnt sure that it would make a huge difference, but it did! Acceleration is is crisper, idle is better (i actually had to turn the idle down a tad!), and over all just feels more responsive! If you decide to do it, you be the judge. Now, on to how i dunnit. First things, first. The parts. I decided I was going touse an e-corecoil, because i wanted maximum benefits. I decided on a coil from a 1996-2000 chebby pickup or SUV because it has a a bracket, and a mounting place with a heat sinc for the module ($25 at the wrecking yard))! I installed an MSD HEI module that a buddy gave me (free, but you can get an HEI moduleat O'Reilly's for $25). And of coarse, wiring connectors and other realted supplies. My install is a little more involved because of the setup i chose, and because i modified (or simplified actually) my engine harness. I decided come hell or high water, this was gonna work, and i removed the wiring for the ballast resisitor and the ecu, as well as the original coil wires. You dont have to do this, you can choose to leave your original wiring just in case.
