Ride height #778827
08/20/10 11:41 AM
08/20/10 11:41 AM
Frankenmuth, Michigan
Beazly464 Offline OP
I have a '68 Plymouth Satellite and was wondering gow to raise the back end hieght up a little bit. I'm going for 1 or 2 inches.
Re: Ride height [Re: Beazly464] #778828
08/20/10 11:51 AM
08/20/10 11:51 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Add a leaf to the springs or have yours rearched.
Re: Ride height [Re: stumpy] #778829
08/20/10 12:35 PM
08/20/10 12:35 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Ride height [Re: Dodgem] #778830
08/20/10 12:57 PM
08/20/10 12:57 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Or buy new/aftermarket rear leaf springs. I have rearched stock springs giving me a lot of height in the rear.
Re: Ride height [Re: stumpy] #778831
08/20/10 03:32 PM
08/20/10 03:32 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Yup, I added a leaf to mine, cheap and easy just like me.
Re: Ride height [Re: Beazly464] #778832
08/20/10 05:57 PM
08/20/10 05:57 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
air shocks. and they stop body roll if it's a problem
Re: Ride height [Re: mikemee1331] #778833
08/20/10 06:24 PM
08/20/10 06:24 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Air shocks are not what you need to use to raise a rear end. Shocks are not made to support the body weight and they will punch the upper shock mounts through the floor. Do it right and do it with springs.
Re: Ride height [Re: stumpy] #778834
08/20/10 07:30 PM
08/20/10 07:30 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
correctly installed air shocks won't do that. they are sold specificly for the purpose of leveling the rear end load when hauling a trailer. i've used them for years with out a problem as long as they are installed right and not 'pumped' up to the max. springs are of course the way to go but the cheap quick fix is the shock.
Re: Ride height [Re: mikemee1331] #778835
08/20/10 08:49 PM
08/20/10 08:49 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
As you say they are to help the springs when you load them. They are not to be used to do the springs job or to raise the car above the springs capacity to do so.
Re: Ride height [Re: stumpy] #778836
08/21/10 03:26 AM
08/21/10 03:26 AM
Manitoba, Canada
Manitoba, Canada
Which is exactly what everybody uses them for. I used air shocks on a rusted to hell dart and never had a problem. However after having had a car with the lift done by springs, I would never go back to the air shock route.
Re: Ride height [Re: Beazly464] #778837
08/21/10 01:03 PM
08/21/10 01:03 PM
ok so now I have to ask how to rearch the springs?
Re: Ride height [Re: Beazly464] #778838
08/21/10 02:41 PM
08/21/10 02:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You remove them and take them to a local spring shop. They do it normally in a day and around here it costs $125. Then you are good for another 30 years.
