Flexable braided brake lines on the street?
#778222
08/19/10 03:39 PM
08/19/10 03:39 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
What are your thoughts on flexable braided brake lines on the entire car for street applications? I am in the process of replacing the front brake hoses with these. I think it looks nicer and a more "perfprmance" look. So I am thinking of doing the entire front brake lines, then at a later point doing the whole car. Any thoughts?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Flexable braided brake lines on the street?
[Re: jrlegacy23]
#778224
08/19/10 04:02 PM
08/19/10 04:02 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Lots of braided lines aren't DOT approved if that matters.
[Re: MR_P_BODY]
#778228
08/19/10 08:46 PM
08/19/10 08:46 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
I run long braided lines to the calipers and the rear axle on my jeep. 7 years now with no trouble.
68 Barracuda Formula S 340
[Re: Bad340fish]
#778229
08/19/10 08:50 PM
08/19/10 08:50 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
This is the best approach......replace all flexible line with braided and leave the hard lines as is. They make some pretty stiff braided brake line , but nothing like solid tubing.
[Re: Dragula]
#778233
08/19/10 09:51 PM
08/19/10 09:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My whole brake system is braided line... works fine but it has a bit of a spongy pedal but not enough for me to run steel line.... yet
[Re: MR_P_BODY]
#778234
08/19/10 10:09 PM
08/19/10 10:09 PM
Posts: 20,191 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I purchased about 8 short pieces of Earl's #3 braided line from Summite ( 4,6,8,18, inch ) to use for the oiling system on the engine I am building. Every piece of line has a sticker " not for highway use " but yet they offered braided line brake kits for about every car known to man. If you ask me they are just covering their butt.
[Re: pittsburghracer]
#778235
08/19/10 10:20 PM
08/19/10 10:20 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Some are DOT approved but the OP wants to replace all of his hardline with braided. I did this once like Mike has his but eventually changed it and got a much firmer peddle.
#778236
08/19/10 10:24 PM
08/19/10 10:24 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Personally, I would never plumb the entire braking system with braided hose, especially on a street car. Hold a plumbed braided brake line in your hand while someone else depresses the brake pedal. You can feel and see it expand. Imagine that amount of expansion over many feet of hose. Don't compromise your braking system. Forget the cool factor, hard line it, except for where there is suspension movement.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#778238
08/19/10 10:47 PM
08/19/10 10:47 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
[Re: bobs66440]
#778239
08/19/10 10:53 PM
08/19/10 10:53 PM
MR_P_BODY
I wouldnt do it again... but at the time it was easy (not cheap but was easy)
[Re: bobs66440]
#778240
08/20/10 03:49 AM
08/20/10 03:49 AM
jrlegacy23
Cooperstown, NY
I am replacing the rubbers now, with DOT approved braided line. I have good metal lines now. Just a thought of plumbing the whole car, guess it would not be a great idea.
