How do I bench test a coil #777998
08/19/10 10:12 AM
08/19/10 10:12 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Can someone tell me how to bench test a coil??
Go Fast and Swerve!
Re: How do I bench test a coil [Re: way2fast] #777999
08/19/10 10:34 AM
08/19/10 10:34 AM
PA
Moparzrule Offline
Moparzrule  Offline
PA
My
Own
Personal
Adrenaline
Rush
Re: How do I bench test a coil [Re: Moparzrule] #778000
08/19/10 11:12 AM
08/19/10 11:12 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Perfect... Thanks!!!!!!!!!!!!!!!!!
Go Fast and Swerve!
Re: How do I bench test a coil [Re: way2fast] #778001
08/19/10 07:20 PM
08/19/10 07:20 PM
douglasville,ga
ramrod Offline
ramrod  Offline
douglasville,ga
You might want to check it when its hot too. Throw it in the oven for awhile at 150 degrees and then check it. I had a coil that checked fine when it was cold but was shorting internally when it got hot!
"That Plymouth had a Hemi with a Torqueflite." -Driver
Re: How do I bench test a coil [Re: Moparzrule] #778002
08/20/10 10:31 AM
08/20/10 10:31 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I have a coil that checks .80 primary, 13,500 secondary. Will a secondary reading over 11,000 trend to burnt out ballasts and ECUs? I went thru 4 ballasts and 2 ECUs within 4 months until I changed this coil out. I now have a MP chrome ECU, Accel 8145 coil and a 1.2ohm balast, 4 years with no failures.
Re: How do I bench test a coil [Re: Moparzrule] #778003
08/20/10 10:56 AM
08/20/10 10:56 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
http://www.mymopar.com/coiltest.htm
Also ohm out coil tower to case, + to case, and - to case. Any reading other than zero = junk, windings are shorted to the case.
Rich H.
Esse Quam Videri
Re: How do I bench test a coil [Re: ZIPPY] #778004
08/20/10 01:18 PM
08/20/10 01:18 PM
CrazyD Offline
CrazyD  Offline
FYI, ohm values spec'd in 69/70 FSM are as follows at 70-80 degrees F:
2444241
Primary 1.41-1.55 ohms
Secondary 9200-10700 ohms
2444242
Primary 1.65-1.79 ohms
Secondary 9400-11700 ohms
Re: How do I bench test a coil [Re: way2fast] #778005
08/21/10 10:06 AM
08/21/10 10:06 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
When I was fooling around checking out the stock Magnum V8 ignition coil,
and the after-market alternatives,
I found in my junk pile a small 'wall wart' transformer
that put out 5 volts AC,
cut off the cord plug,
and connected the wire ends to the low side terminals of the coil,
then measured the AC output voltage of high side of the coil by measuring with an AC voltmeter from the center high voltage connector to ground.
This allows you to measure the 'turns ratio' of the internal wiring of the ignition coil.
The turns ratios of stock ignition coils usually lie in the 60 to 100 range.
The turns ratio can also be used to find the 'inductance' of the coil.
This online web app from the 'MegaSquirt Guys' allows simulating how a ignition system 'might' perform if you know some of these measurements:
http://www.bgsoflex.com/igncoil.html
