Anybody got aftermarket tubs in a stock framed car? #777115
08/19/10 12:12 AM
08/19/10 12:12 AM
Cooperstown, NY
jrlegacy23 Offline OP
Cooperstown, NY
I am having my 72 Dart miinitubbed to the stock frame rails. The guy doing it has asked me to buy the aftermarket tubs as this is the way he likes to do it.
I need to know what size tubs (front to back) fits in A-Bodies best. I have measured 33" long. So I was thinking of ordering the 34"ers because they will fit with room to adjust.
Also anyone got pics of aftermarket tubs in a stock floor and framed car?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: Anybody got aftermarket tubs in a stock framed car? [Re: jrlegacy23] #777116
08/19/10 12:22 AM
08/19/10 12:22 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
For the small amount of tub you could stuff in there , I don't see this as being very beneficial.
I used around 80 inches of 3" X .060 cut in 12 to 15 inch strips and got about as much room as you're gonna get in there.
It would be easier and probably cost about the same to buy a Chi com bead roller and make your own tubs , because you will be cutting away most of any aftermarket tub that I am aware of.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: tubtar] #777117
08/19/10 12:29 AM
08/19/10 12:29 AM
Cooperstown, NY
Cooperstown, NY
I realize that, but he is giving me a great deal.. pactically free tubbing job and he prefers to do it this way. I have never done a tub job, let alone any "real" welding, so I will go his way. I found a place that has 16ga fully tig welded tubs 32", 34, and 36" for $129.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: jrlegacy23] #777118
08/19/10 12:29 AM
08/19/10 12:29 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I've got aftermarket tubs in my valiant that's tubbed to the frame rails. I think the smallest you can get is 36" at Summit and Jegs, that's what i've got at least. Unfortunately i don't have any pics of the install...-Andy
Re: Anybody got aftermarket tubs in a stock framed car? [Re: 340_Dart] #777119
08/19/10 12:31 AM
08/19/10 12:31 AM
Cooperstown, NY
Cooperstown, NY
Andy, do have trunk pics of the finished product?
I found a place that has 32" and 34", 16ga tubs
Re: Anybody got aftermarket tubs in a stock framed car? [Re: jrlegacy23] #777120
08/19/10 12:33 AM
08/19/10 12:33 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
I can probably get some pictures tomorrow. i moved mine up in the body as much as possible, that way i can really lower the car if i want..
Re: Anybody got aftermarket tubs in a stock framed car? [Re: 340_Dart] #777121
08/19/10 12:45 AM
08/19/10 12:45 AM
Cooperstown, NY
Cooperstown, NY
I like the idea of that, I plan on lowering the car for a meaner stance. I would love to see some pics when you can.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: 340_Dart] #777122
08/19/10 12:45 AM
08/19/10 12:45 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Anybody got aftermarket tubs in a stock framed car? [Re: bigtimeauto] #777123
08/19/10 03:51 AM
08/19/10 03:51 AM
Cooperstown, NY
Cooperstown, NY
Bigtime, I like the sharp corners of your trunk.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: jrlegacy23] #777124
08/19/10 02:54 PM
08/19/10 02:54 PM
Cooperstown, NY
Cooperstown, NY
Anyone else have any pics?
Re: Anybody got aftermarket tubs in a stock framed car? [Re: jrlegacy23] #777125
08/19/10 03:14 PM
08/19/10 03:14 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
Get the bigger tubs and get as close to the package shelf as possible. Mine were too small and too low at first and the tires rubbed the top of the tub on bumps. SS springs,2" lowering blocks, 11.5x29.5 Phoenix.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: BADDART] #777126
08/19/10 03:32 PM
08/19/10 03:32 PM
organ
maximum entropy Offline
organ
that's exactly how mine is set up. i also folded the lip on the frame rail. some cut it off, i preferred to leave it and fold it up to form a flange for added purchase with the tubs, and keep the rails as strong as possible (they're not very thick). you'll be able to fit surprisingly large rubbah. i have 16.5 inches between the frame and fender. is your car caged? the stock wheel houses are a structural element, and i wouldn't replace them with tubs if the car isn't caged.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: jrlegacy23] #777127
08/19/10 04:03 PM
08/19/10 04:03 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We tubbed our car in 1981.Used a S&W tub kit,using a 15x12 wheel with a 31.8" tall Phoenix tire.
Nautilus Racing-
Re: Anybody got aftermarket tubs in a stock framed car? [Re: Chris2581] #777128
08/19/10 04:11 PM
08/19/10 04:11 PM
Cooperstown, NY
Cooperstown, NY
I am not caged, that is the reason why I am going with 16ga instead of the summit 24ga metal.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: jrlegacy23] #777129
08/19/10 04:24 PM
08/19/10 04:24 PM
organ
organ
the stock wheel houses triangulate the sail panels, the frame, the outer fender, and the sill bar. it's amazing how flabby the whole thing gets when you pull them out. maybe someone has done it without a cage and has a way?
Re: Anybody got aftermarket tubs in a stock framed car? [Re: maximum entropy] #777130
08/20/10 12:03 AM
08/20/10 12:03 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Good point! i forgot to mention that if you're thinking of putting aftermarket tubs in the car, it'd better have at least a roll bar in it. The factory wheel tubs (outer section at least) tie the whole back of the car together.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: 340_Dart] #777131
08/20/10 03:36 AM
08/20/10 03:36 AM
Cooperstown, NY
Cooperstown, NY
I would like to get a hoop and some frame connectors in at some point.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: maximum entropy] #777132
08/20/10 03:53 PM
08/20/10 03:53 PM
Detroit,MI
BADDART Offline
BADDART  Offline
Detroit,MI
Yes my car is caged and the tubs are steel and fully braced and welded to the quarters.Leaves hard and straight! Chris
Re: Anybody got aftermarket tubs in a stock framed car? [Re: BADDART] #777133
08/20/10 04:00 PM
08/20/10 04:00 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mine looks like the rest here but I have the spare tire well.
Re: Anybody got aftermarket tubs in a stock framed car? [Re: BADDART] #777134
08/20/10 09:55 PM
08/20/10 09:55 PM
Cooperstown, NY
Cooperstown, NY
I thought the aftermarket tubs are not supposed to be welded to the quarters ???
