Help with front end question #777055
08/18/10 11:06 PM
08/18/10 11:06 PM
wisconsin
swifter Offline OP
swifter  Offline OP
wisconsin
Had front end alignment done on my duster,had them go thru everything--looked under car when i got it home and the torsion bar adjusting bolts are at different thread depths the driver side screwed in further than the passenger?? are they supposed to be equal????? Thanks Steve--yes I had then adjust the ride height and yes they are a mopar shop
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Help with front end question [Re: swifter] #777056
08/18/10 11:10 PM
08/18/10 11:10 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
As long as the ride is right and side to side is ok.The bolt depth is nothing to be worried about.almost never, are they the same.
Re: Help with front end question [Re: moretoys] #777057
08/18/10 11:18 PM
08/18/10 11:18 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Help with front end question [Re: swifter] #777058
08/18/10 11:23 PM
08/18/10 11:23 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
As noted the adjusters are seldom if ever equal. The reason is easily understood if you look at the rear "T" bar anchors in the crossmember. The anchors are cylindrical units that are welded [ not always very well ] into holes in the crossmember. Seldom if ever are both of them "clocked" the same. If they were "clocked" equally then assuming that neither of the "T" bars has sagged the adjuster bolts would screw in equally for a given ride height.
Re: Help with front end question [Re: 5spdcuda] #777059
08/18/10 11:33 PM
08/18/10 11:33 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
i would not worry about it, typically i set the d/s torsion a little higher on the d/s to hepl with driver weight.
