440 distributor problems
#776899
08/18/10 08:06 PM
08/18/10 08:06 PM
Posts: 65 Solon, Oh
Convertible Bee
Solon, Oh
Have been chasing a low speed to part throttle miss on my 440. Can pull all wires one at a time (except #2) at the distributor with little effect on the idle or sound of the miss. Here's where i'm stumped, pull #2 engine dies every time, put a test wire with a plug to ground the engine runs the same as when the other 7 are removed one at a time. Any thoughts? I've tried new cap, wires, plugs, even changed to an optic pick up, same symptoms every time. compression is 172-179psi on all cylinders cam lobes intake +- .004 exhaust +- .003 Thanks Tim
Re: 440 distributor problems
[Re: Convertible Bee]
#776903
08/18/10 09:44 PM
08/18/10 09:44 PM
Posts: 679 N.E Indiana
repad
super street
super street
N.E Indiana
Thanks Tim
put a test wire with a plug to ground the engine runs the same as when the other 7 are removed one at a time. Can you clarify this statement, not sure what this means. To me, this sounds like either a couple of bad wires or a couple of crossed wires. Which brand/size wires are you using?
#776905
08/19/10 04:33 PM
08/19/10 04:33 PM
Posts: 308 michigan
black64
michigan
Hi, have tried mopar direct fit 7mm wires, new just before driving to the nationals last friday, msd 8mm today, new cap + rotor today.
Test wire was the extra wire from msd set installed in #2 on distributor and sparkplug held on the engine block to see if it would spark.
As I noted, engine will start and run while I hold the plug to the block, Note that #2 cylinder has nothing hooked at this point. When I lift the plug i'm holding to the block the engine stalls.
firing is ccw 18436572 checked that many times.
Have you tried a new plug in #2. Sounds like the plug is shorting to ground under load.
