Fuel sending unit resistance - How to measure?
#776810
08/18/10 05:25 PM
08/18/10 05:25 PM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
I measured from the post on the unit to the bare metal of the unit and got very high readings.
I also measured from the terminals on the back of the autometer gauge, through the wires to the unit and got very high readings.
The readings were "backwards" meaning I had a lower resistance at empty than at full. Th book says I should have a lower reading at full than empty.
The values were in the 790Kohm range to an open circuit range when full.
Supposed to be 33ohms empty and 8ohms or so full.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: Fuel sending unit resistance - How to measure?
[Re: 70Coronet500Vert]
#776812
08/18/10 08:28 PM
08/18/10 08:28 PM
Posts: 571 Beaverton, OR, USA
Alikazam
super gas
super gas
Beaverton, OR, USA
I assume you are using a stock fuel level sender with an autometer gauge designed for that range? Just making sure! ![](/ubbthreads/images/graemlins/smile.gif)
[Re: Alikazam]
#776813
08/19/10 08:25 AM
08/19/10 08:25 AM
70Coronet500Vert
St Charles MO
Actually the autometer gauge in the car is wrong for a stock sender. It is a 2320. I think it is supposed to be a 2315. however, it is wired correctly and not measuring anything, so I wanted to verify the resistance of the circuit.
I think the sender, aftermarket or stock, is bad. The 2320 takes a 3625 sender or something. Not stock.
[Re: NachoRT74]
#776815
08/19/10 03:42 PM
08/19/10 03:42 PM
Posts: 3,908 Oregon
hooziewhatsit
try adding another ground from the swinging arm to the rest of the filler body, then check the resistance measurements again. (A simple wire with alligator clips would be fine for testing)
