Why do trim tags often have mis-stamped numbers ? #776767
08/18/10 04:32 PM
08/18/10 04:32 PM
Alabama
gold1950 Offline OP
gold1950  Offline OP
Alabama
I'm trying to understand why so many MOPAR trim tags / fender tags have erroneous mis-stamped numbers in odd locations. It almost looks like they went through the press with stuff under the tag.
They quite often have numbers or letters in strange locations (not part of the build information)....crooked....etc..
Is this just poor quality or were they done so fast that they often had stuff from the last tag under the one currently being stamped ?
Re: Why do trim tags often have mis-stamped numbers ? [Re: gold1950] #776768
08/18/10 04:44 PM
08/18/10 04:44 PM
Highland, Michigan
1972Rallye Offline
1972Rallye  Offline
Highland, Michigan
Usually crooked or misaligned staps are actually inspectors' stamps - most common on Lynch Rd. cars. They appear as numbers/letters or punch marks.
Re: Why do trim tags often have mis-stamped numbers ? [Re: 1972Rallye] #776769
08/18/10 05:53 PM
08/18/10 05:53 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
This is correct and they are usually found on st. louis tags though they look quite different.
