OK. What did I do wrong on my 9 1/4:
My 1976 9.25 open 2.71.
Bought: 3.55 R&P Out of a 92 Jeep) used for $25
R&P gears looked new.
Dropped out carrier, unbolted 2.71 ring gear, installed 3.55 ring gear, reassembled.
I took 2.71 pinion out, pulled off gear, left shims in place, installed 3.55 gear.
Reinstalled pinion into carrier 100% by the FSM
Reinstalled carrier .
Everything new . Reputable Master Kit.
Set side-to-side thrust by special tool going down the axle housing. By the manual. Again:
Took a test drive around block. WHINE @45
Drove directly to a shop that specializes in custom drivetrains. Redid the whole thing I did using my existing parts, in abut 45 min. Bolted it up and said you're good to go. And he was right.
I need this for a future "Ask me how I know..."
