'68 and '70 B Body K Frame, LCA help needed #776115
08/17/10 09:05 PM
08/17/10 09:05 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
Can anyone tell what the difference is in a '68 K and a '70 K and the LCA's ( Both with sway bar tabs).
I am doing a drum to disc swap and was suggested to switch to a '70 k and LCA set-up for ease of parts finding and not fooling with brake hose issues.
Here is a link to my thread I started Drun to Disc Thread
I have everything now to put my suspension together and brakes except the hoses. If I decided to go the '70 route can I use all my suspension parts??
I would appreciate if anyone can help me on this!!
Chuck
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776116
08/17/10 09:30 PM
08/17/10 09:30 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
late 1966-1969 have sway bar tab on shock bolt mount for front mount sway bar,1970 has middle mount tab for sway bar goes inside k-frame. hope this helps
MOPAR OR NO CAR
Re: '68 and '70 B Body K Frame, LCA help needed [Re: hemigod426] #776117
08/17/10 09:47 PM
08/17/10 09:47 PM
Mansfield,Ohio
Mansfield,Ohio
So I would need to use the 70 LCA's on '70 K frame correct? I couldn't get away with using the 70 LCA's on my '68 K?
I want to run a sway bar and not fool with the sway bar to caliper interference.
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776118
08/17/10 09:52 PM
08/17/10 09:52 PM
Mansfield,Ohio
Mansfield,Ohio
I just realized I already have my TTI headers, will switching to a '70 K frame alter the fit of these??
This may be more trouble than its worth!!
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776119
08/17/10 09:58 PM
08/17/10 09:58 PM
hemigod426 Offline
hemigod426  Offline
the 66-69 lcas will bolt right on with 70 k frame but you will have drill the 4 holes in it for front mount sway bar, headers will fit both the same. if i were you id use 68-69 kframe same as 318 car, and get 66-69 lcas with tabs to look correct for your car, or are you working on a 1970 car?
MOPAR OR NO CAR
Re: '68 and '70 B Body K Frame, LCA help needed [Re: hemigod426] #776120
08/17/10 10:10 PM
08/17/10 10:10 PM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
Did this brake swap on my 69 bee. Used the 70K frame and LCA's and a firm feel front bar. I'm happy.
Re: '68 and '70 B Body K Frame, LCA help needed [Re: hemigod426] #776121
08/17/10 10:16 PM
08/17/10 10:16 PM
Mansfield,Ohio
Mansfield,Ohio
I have a '68 Coronet w LCA that have tabs for sway bar. I am swapping the drums for disc's and will have a caliper to sway bar contact issue. Mounting the calipers to the rear is a option but then I have the brake hose issues and getting some made.
Was told it would be easier and easier to get replacement parts if I went to a '70 K and LCA's
due to the way they mount.(No more interference) If I could get away with just the '70 LCA's that would be great as my '68 K is powder coated.
I don't care about correctness (nothing on car correct)
I guess my question boils down to do I need the 70 LCA and K or can I use the '70 LCA's on my'68 K.
And if I need to switch to '70 K/LCA's, will all my suspension parts I have been buying thru this rest-mod be usable.
I really want to run sway bars or I wouldn't worry about it.!!
Thnx
Re: '68 and '70 B Body K Frame, LCA help needed [Re: myrddin] #776122
08/17/10 10:18 PM
08/17/10 10:18 PM
Mansfield,Ohio
Mansfield,Ohio
Is the 70 K different from your '69, I guess you couldn't use the '70 LCA's on the '69 K
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776123
08/17/10 10:22 PM
08/17/10 10:22 PM
hemigod426 Offline
hemigod426  Offline
Thnx
dude real easy keep your 68 done k frame in car, swap spindles left to right and it rear mounts calipers then get 1973 charger front brake hoses done deal been doing it for years, depending on calipers if even done it with rear mount pin type calipers which everyone has problems with those worked mint with 1970 cuda/super bee hoses from napa. and keep front 68 bar and lcas
MOPAR OR NO CAR
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776124
08/17/10 10:25 PM
08/17/10 10:25 PM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
The sway bar actually goes through the middle of the 70k frame. I did it for the same reason. To avoid the caliper to sway bar interference on my drum to disc swap. The sway bar tabs on the 70 lca are also in a different location than the 69 arms, avoiding any contact the bar might have with the calipers.
Re: '68 and '70 B Body K Frame, LCA help needed [Re: myrddin] #776125
08/17/10 10:41 PM
08/17/10 10:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Your headers will fit, it's worth doing...
70 K complete...
Re: '68 and '70 B Body K Frame, LCA help needed [Re: 1_WILD_RT] #776126
08/17/10 10:44 PM
08/17/10 10:44 PM
hemigod426 Offline
hemigod426  Offline
70 K complete...
not if your car is a factory sway bay 68-69 performance car, not a a/c sway bar car. it would be mutt job, what would you be gaining??
MOPAR OR NO CAR
Re: '68 and '70 B Body K Frame, LCA help needed [Re: hemigod426] #776127
08/17/10 10:58 PM
08/17/10 10:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
70 K complete...
not if your car is a factory sway bay performance car, not a a/c sway bar car. it would be mutt job, what would you be gaining??
The late style disc brakes fit properly without rear mounting them... If you front mount the late calipers they hit the early type sway bar.. Many simply rear mount the calipers but when you rear mount the calipers the brake hoses no longer cross the centerline of the steering axis... Crossing the axis minimizes the likelyhood of excessive strain on the brake hose from steering motion... Lots of guys do it, but look at any factory engineered car & the hose will cross the axis.... You think thats just a fluke?
Re: '68 and '70 B Body K Frame, LCA help needed [Re: 1_WILD_RT] #776128
08/17/10 11:05 PM
08/17/10 11:05 PM
Mansfield,Ohio
Mansfield,Ohio
If I find a set of '70 LCA's and a '70 sway bar can I use it on my '68 K Frame? (I don't care if I need to drill holes in K frame)
I don't dought anyones advice here and I appreciate all thats been posted, its been helpful.
I will reread these posts when I am not crosseyed tired, in case the answer to my question has already been answered!!
Just for the record I am partial to mounting the calipers forward, nothing on the front is assembled as of yet
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776129
08/17/10 11:08 PM
08/17/10 11:08 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
If your using a 68 K the 70 swaybar won't work...
This picture may help.. Actually a 69 M code K..
Re: '68 and '70 B Body K Frame, LCA help needed [Re: 1_WILD_RT] #776130
08/17/10 11:18 PM
08/17/10 11:18 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx for the clarification Randy. All my bushings, torsion bar, strut rods etc.. will work as well wont they?
Like I said I have EVERYTHING except the brake hoses. (except If I switch to '70)to put the front end together. I would hate to have to buy all this crap over....
Chuck
Re: '68 and '70 B Body K Frame, LCA help needed [Re: hemigod426] #776131
08/17/10 11:20 PM
08/17/10 11:20 PM
Mansfield,Ohio
Mansfield,Ohio
Thnx for the help Hemigod!! I appreciate your input!!
Re: '68 and '70 B Body K Frame, LCA help needed [Re: 1_WILD_RT] #776132
08/17/10 11:33 PM
08/17/10 11:33 PM
hemigod426 Offline
hemigod426  Offline
70 K complete...
The late style disc brakes fit properly without rear mounting them... If you front mount the late calipers they hit the early type sway bar.. Many simply rear mount the calipers but when you rear mount the calipers the brake hoses no longer cross the centerline of the steering axis... Crossing the axis minimizes the likelyhood of excessive strain on the brake hose from steering motion... Lots of guys do it, but look at any factory engineered car & the hose will cross the axis.... You think thats just a fluke? [/quote mostly right, most have failed rear mount by dart calipers hiting shock bolt,hoses too short,hoses rubes on lcas,hose pinching on turns, if you have an a-12 car or 66-69 hemi cars you want to retain the correct stock k-frames,and sway bars, not barning 1970 k-frames into every thing. ive made my brake kits work mint with all mopar parts and the better i think pin type calipers from 1973-78 mopars much stronger mounting.and also with the large pin type caliper adaptors can go up to police 11.75 from 10.75 discs, also have my kits on my race cars stops mint @ 100mph plus in 1/8 drags with no shut down at my track and right angle turn and the end many car go in the woods every year that run slower. if you cant figure out how to right with factory parts, theres many kits out there that go right on your drum spindle done deal no quess work
MOPAR OR NO CAR
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776133
08/17/10 11:46 PM
08/17/10 11:46 PM
AndyF Offline
AndyF  Offline
At this point the easiest thing for you to do is to just finish it up with rear hung calipers. Don't you already have the correct Volare calipers? All you need is a set of the correct hoses made for the car and you're done. Don't do a hack job with incorrect hoses, just get a set of custom ones made that fit properly. It only costs about $50 for a pair of hoses and then you're all finished.
Re: '68 and '70 B Body K Frame, LCA help needed [Re: moparrulzzz] #776134
08/17/10 11:50 PM
08/17/10 11:50 PM
hemigod426 Offline
hemigod426  Offline
heres some pics of one race car fenders are off for repaint, can see better
MOPAR OR NO CAR
