BB Distributor springs/advance place?
#776075
08/17/10 08:20 PM
08/17/10 08:20 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Hopefully a quick one: Are the advance springs in a distributor supposed to match one another? The reason I ask is because I just tore down my distributor (to remove the wheel bearing grease..... ![](/ubbthreads/images/graemlins/eyes.gif) ) and found this: ![](http://i149.photobucket.com/albums/s49/pwhalen144/Trucks/80RC/IMG_20100817_160248.jpg) The heavier looking spring on the left doesn't contact the weight until it has moved out a bit, as where the lighter (white) spring on the right is always in contact with the weight. ![](http://i149.photobucket.com/albums/s49/pwhalen144/Trucks/80RC/IMG_20100817_160257.jpg) The advance plate has a 13R on the underside of it. I understand that this means 26* of total advance. Is this suitable for a stock/mild 440 in a heavy truck for daily driving? I just want to make sure I get this right when I put it all back together. Thanks ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: BB Distributor springs/advance place?
[Re: Pat_Whalen]
#776076
08/17/10 08:48 PM
08/17/10 08:48 PM
Posts: 40 Corona CA
wyotech_cuda440
Corona CA
That's normal, it's a dual curve dist. The dizzy advances easily on the light srping at lower rpm untill the stronger spring makes contact. Then it has to pull both springs at higher rpm to advance further.
Daily driver: 2002 Dakota R/T, slightly modded
Weekend machine: 70 cuda, 440-6 street/strip
[Re: wyotech_cuda440]
#776078
08/17/10 09:05 PM
08/17/10 09:05 PM
Posts: 3,911 Oregon
hooziewhatsit
Yep, exactly what he said.
Assuming a total timing around 34*, that would only leave you with 8* initial. Ideally, you would mess with it and see what initial it likes (maybe more than 8*?), then weld the inside of the slots closed to limit the total advance.
On my 318 I replaced the heavy spring with another light spring to bring the total timing in sooner. Most seem to shoot for full advance by 2000 rpms or so.
I would put it back together, then with a helper, write down the advance at 500 rpm increments and see what you have. Then you can tweak it from there.
[Re: hemigod426]
#776080
08/17/10 09:32 PM
08/17/10 09:32 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
while you got it out put a little weld and shorten the curve, and regrease
Wouldn't welding the advance plate lower the amount of overall timing the dist. puts in? I can understand the desire for this from a performance standpoint, but from an economical daily driver standpoint, wouldn't this be a bad thing?
[Re: hooziewhatsit]
#776082
08/17/10 11:09 PM
08/17/10 11:09 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Yes, that would limit the advance from the dist, allowing more initial timing. From what I understand, running more initial at idle usually gives a better idle and better throttle response. My 318 runs pretty well at 17* initial.
Then you want your total advance as soon as you can to get the best performance at cruising RPMs.
I have found that my 440 is happiest at around 15* initial. Which I guess comes out to about 41*. Too high? When I get the engine running again, I'll be sure to go in 500rpm increments up until full advance and map it out. I'll probably still end up sending my dist to Don with FBO so he can curve it better for my application.
All this might seem a little pointless, seeing as I'll be going fuel injected on the 440 in a matter of months (hopefully), at which point timing will be controlled by a computer rather than a dist.
[Re: hooziewhatsit]
#776083
08/17/10 11:13 PM
08/17/10 11:13 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
once you run any type of performance cam or want performance. this is trick i use on more radical cars/cubes/cams 20 initail advance and shorten the dizzt plate to 16 degrees 36 total all in by 2500. mild stuff 12-16 base timing and limit plate to 20 degrees advance all in by 3k, all stock dizzys have way to much in the plate i shorten all types msd,mopar,440 sourceect.. Yes, that would limit the advance from the dist, allowing more initial timing. From what I understand, running more initial at idle usually gives a better idle and better throttle response. My 318 runs pretty well at 17* initial.
MOPAR OR NO CAR
[Re: VanishPt]
#776087
08/18/10 07:02 PM
08/18/10 07:02 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
So not to get too far off topic here, but what would be a reason you'd want a lower initial timing? Like I said, my 440 seems to like around 15* initial. Quick cranking, no problem on hot restarts, plenty quick on throttle response. But with 15* initial and this 36* advance, that puts me at 41* total. I'm not sure what RPM that is at yet, but I'll find out. Is 41* too drastic? What happens when you start running higher advances?
[Re: Pat_Whalen]
#776088
08/18/10 07:47 PM
08/18/10 07:47 PM
hemigod426
15-16 base is good like i say for 509-590 cams but you must shorten dizzy curve to 20 for 16+20=36 total. if your running 41 degrees thats nuts will over heat,chew mad fuel, it will break rings/pistons ect..the mopar tech line rang off the hook when new m/p electric kits came out with vac nipple on dizzy them guys would put in the 509 cam with conversion kit and wonder why its slower than stock, and pings crazy. they would hook up vac advance and mech and have timming over 50 degrees total....
MOPAR OR NO CAR
[Re: hemigod426]
#776089
08/18/10 07:53 PM
08/18/10 07:53 PM
Posts: 3,911 Oregon
hooziewhatsit
With too much total you'll get pinging, which can lead to the issues listed above.
At part throttle cruise, the vacuum advance will add advance so you're in the 50* range. This is normal and desired for better fuel mileage.
Under WOT the vac advance drops out so you only have initial + mechanical for ~36* total.
[Re: Pat_Whalen]
#776091
08/18/10 10:26 PM
08/18/10 10:26 PM
Posts: 493 Arizona
az426john
Arizona
Pat does it ping in it's current configuration shown above when you step down on it hard under a heavy load?
[Re: az426john]
#776092
08/19/10 12:52 AM
08/19/10 12:52 AM
Pat_Whalen
super gas
super gas
Mesa, AZ
John:
No idea. Haven't been able to "load" the engine. Only took it for one quick jaunt down the road at about 45-50 and got on it once and didn't hear any pinging. Sitting still in the driveway I don't hear any pinging when I rev it.
[Re: VanishPt]
#776093
08/19/10 09:07 AM
08/19/10 09:07 AM
Posts: 236 Maryland
cudaboone
Maryland
I have a 254/262 solid roller in a 511 Hemi. I use @23* initial and limit total to @33*. Cranks like it does not have plugs in it.
My slots be real short.
My 528 has comp solid roller 248/248. Seems to run best at 20 initial and currrently 34 total. Am going to try 32 total with a 10 degree bushing that i have. Was told that it should be 32 total. Mine also cranks pretty easily. I have the msd starter saver, but don't think i needed it.
