74 Challenger wheel fitment #775968
08/17/10 06:22 PM
08/17/10 06:22 PM
Texas, Dallas
daytonadave2010 Offline OP
Texas, Dallas
I'm looking to put 18" Foose Nitrous wheels on a 74 Challenger. What are the widest tires that will fit if it is lowered 2" front and rear. The car has the rear leafs moved inboard with the Mopar kit as well. Anybody tried a 315 rear tire? Also, anybody have exact backspacing, offset, etc. that would work? Most websites try to put a 15" wheel on the car or a stock width wheel. Thanks for the help!
Re: 74 Challenger wheel fitment [Re: daytonadave2010] #775969
08/17/10 07:18 PM
08/17/10 07:18 PM
BDW Offline
BDW  Offline
Re: 74 Challenger wheel fitment [Re: BDW] #775970
08/17/10 07:23 PM
08/17/10 07:23 PM
BDW Offline
BDW  Offline
Read through this
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
I have 9" rims, could have fit 10" with no problem. 315's might be tight with the Mopar relo kit. It only gives you 0.75" inward I believe.
Re: 74 Challenger wheel fitment [Re: BDW] #775971
08/18/10 01:08 AM
08/18/10 01:08 AM
Texas, Dallas
Texas, Dallas
Thanks for the info! About to score some BOSS 338's instead of the Foose wheels. Too darn expensive!
Re: 74 Challenger wheel fitment [Re: daytonadave2010] #775972
08/18/10 09:25 AM
08/18/10 09:25 AM
30 miles west of EuroDisney
fbernard Offline
fbernard  Offline
I have 9.5" rims, 19" diameter so no tire balooning, with 275 tires. That was fitted with springs in OEM position. I now have the lower Street Lynx rod instead of the spring, which would be good for another inch almost, probably similar to moving the springs inboard. 305 certainly, 315 maybe. It all depends on tire section width.
Above 17" should not be a problem, tire width is very close to tread width.
Don't take measurements from other people, measure your own car and be sure to do both sides. I did not have the same clearance on both sides, until I installed the street-lynx and really centered the rear-end.
