cuda shaker problems aluminum heads six pack?
#775874
08/17/10 02:49 PM
08/17/10 02:49 PM
Posts: 113 Hereford, TX
goose
Hereford, TX
I have a set of pro comp heads on a 440 in a 71 cuda with an edelbrock six pack intake and demon six pack carbs. Is there any way i can get the shaker to fit right? I think the heads lift the intake up about 1" or so. Does anyone make an extra low carb adapter to drop the air cleaner down a bit? How close can the shaker safly be to the hood?
thanks
73 roadrunner, 6-71 blown 408, 727
70 challenger r/t
71 cuda
Re: cuda shaker problems aluminum heads six pack?
[Re: goose]
#775875
08/17/10 05:07 PM
08/17/10 05:07 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Are you 100% sure the heads raised the stock style edelbrock aluminum intake an inch? I used aluminum Indy EZ heads with the Edelbrock aluminum intake and the stock height Holley mechanical secondary carbs. It sits up higher than stock, and fits slightly tighter under the shaker hood, but it works fine and it looks cool sticking up higher. I've seen some that were so low the openings to the scoop are almost below the trim ring line.
You will likely need to modify your base plate to get it to work with your set-up. Either that or shim your K-frame down some.
I do believe the mighty mount engine mounts i'm using raised the engine slightly higher than the stock mounts though.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#775876
08/18/10 02:53 PM
08/18/10 02:53 PM
goose
Hereford, TX
Mine fits real close to yours, (thanks for the picture) the front bottom of the bubble rubs on the bottom of the hood right before i latch it. If i push down on it it latches. How tight can the seal be against the hood?
70 challenger r/t
71 cuda
[Re: jbc426]
#775879
08/22/10 03:43 PM
08/22/10 03:43 PM
goose
Hereford, TX
do you have a picture of just the air cleaner? The back of my air cleaner is about even with the back of the hood without the trim ring on it and the front of the air cleaner sticks above the hood about 3/4 of an inch? thanks
70 challenger r/t
71 cuda
[Re: goose]
#775880
08/22/10 07:22 PM
08/22/10 07:22 PM
jbc426
West Coast, USA
I'm not sure if you can see what you need from this picture, but from what you are describing, you're going to need to get things lower either by shimming your K-member and/or modifying your air filter so the bubble sits lower.
