68 b body, What goes under this bolt ? #775682
08/17/10 01:44 AM
08/17/10 01:44 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
In the dash steering column support....
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775683
08/17/10 04:35 AM
08/17/10 04:35 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Good question. My 68 is an auto car and did not use that hole. Maybe a 4-speed thing?
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775684
08/17/10 09:37 AM
08/17/10 09:37 AM
mn.
P
prairiechicken1 Offline
P
mn.
That hole is for brace that runs from lower dash mount bolt to that hole on a four speed car,not sure on auto.
Re: 68 b body, What goes under this bolt ? [Re: prairiechicken1] #775685
08/17/10 10:08 PM
08/17/10 10:08 PM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks Jim, Prairie Chicken,
Looks like another part to find
It is a 4 speed car
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775686
08/17/10 10:40 PM
08/17/10 10:40 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
yes four speed support rod for 3rd pedal, 4 gear only ill see if i have any more in shop
MOPAR OR NO CAR
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775687
08/17/10 10:43 PM
08/17/10 10:43 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
The brace is for an automatic car also.
Re: 68 b body, What goes under this bolt ? [Re: LTLBEE] #775688
08/17/10 10:44 PM
08/17/10 10:44 PM
NY
LTLBEE Offline
LTLBEE  Offline
NY
Another
Re: 68 b body, What goes under this bolt ? [Re: LTLBEE] #775689
08/17/10 10:51 PM
08/17/10 10:51 PM
New Jersey
myrddin Offline
myrddin  Offline
New Jersey
I always thought those came on verts
Re: 68 b body, What goes under this bolt ? [Re: myrddin] #775690
08/18/10 12:40 AM
08/18/10 12:40 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
WOW, you guys are the best, thanks.
It looks like it goes to the dash support bolt...
I will dig around but I dont remember taking that out of the car.., or seeing it.. it must be 20 inches or so long...
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775691
08/18/10 10:33 AM
08/18/10 10:33 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I just parted another 68 RR auto from St Louis plant. It did not have that brace
Re: 68 b body, What goes under this bolt ? [Re: rrunner] #775692
08/19/10 06:35 PM
08/19/10 06:35 PM
North NJ
a6t9vette Offline
a6t9vette  Offline
North NJ
Although not a 68, my 69 RR (auto) has this brace as well....
69 Road Runner, numbers matching 383, Auto.
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775693
08/20/10 12:49 AM
08/20/10 12:49 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Again, I want to thank everyone that responed to this post.
I have located the rod and installed it. Best part is it was already cleaned and painted !
Here is hoping I can get the rest of the car back together before I loose the what is left of my memory..
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775694
08/20/10 09:05 AM
08/20/10 09:05 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
That rod is in the way with tic toc tac rallye gauges.....looks like it was missing from the factory with my 69 Bee.....I had a 69 parts car with standard gauges and it was there.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 68 b body, What goes under this bolt ? [Re: sthemi] #775695
08/20/10 10:32 AM
08/20/10 10:32 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Nothng to add here, but in your pic with the rod installed your 'protected' shift lever looks alot like my hands at the end of a long weekend thrashing on the car.
Re: 68 b body, What goes under this bolt ? [Re: srt] #775696
08/20/10 03:17 PM
08/20/10 03:17 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
Thats what I thought it was at first glance too, was someones hand.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: 68 b body, What goes under this bolt ? [Re: bobbyb] #775697
08/20/10 03:51 PM
08/20/10 03:51 PM
OK
David_Trimble Offline
OK
This raises a couple of questions I have:
1) Was this rod also used in 1969 B bodies, too? (specifically Chargers, but I would imagine Super Bees too)
2) If 1) is true, then was it only used in non-tic-toc-tach equipped cars?
Thanks!
David
'69 Dodge Charger R/T
Re: 68 b body, What goes under this bolt ? [Re: David_Trimble] #775698
08/21/10 01:03 AM
08/21/10 01:03 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
You are right, it does look like a hand...
Here is hoping my hand will be on the shifter soon !
Re: 68 b body, What goes under this bolt ? [Re: David_Trimble] #775699
08/21/10 11:49 AM
08/21/10 11:49 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
both of my '69 coronets have it. they both have the standard dash.
Re: 68 b body, What goes under this bolt ? [Re: cornucopia] #775700
08/22/10 01:31 PM
08/22/10 01:31 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
My late 68 4spd RR has the brace. May be a 4spd thing or just a later addition to all 68's.
Re: 68 b body, What goes under this bolt ? [Re: rrunner] #775701
08/22/10 09:38 PM
08/22/10 09:38 PM
Mobile Al
hemirdrnnr Offline
hemirdrnnr  Offline
Mobile Al
My 68 was built in Oct of 67 it has the brace.It is auto column shift
