Pushrod length/adjuster threads
#775601
08/17/10 12:37 AM
08/17/10 12:37 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
If you had no choice, would you rather have 1.25-1.5 thread sticking out of the bottom of the rocker or 3.5 threads?
Yeah, I know neither is right. But, money is tight (My employer is taking away my travel check (my fun money) so one of them will have to do) and I need to use what I have.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Pushrod length/adjuster threads
[Re: MR_P_BODY]
#775603
08/17/10 01:30 AM
08/17/10 01:30 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Whats the rocker arm manufacture say? Jesel calls for 3/4 thread as idea, no more than 1 1/2......If I am at 1 1/2 thread IMO its pretty good shape....3 treads is too much, and I would be looking at longer push rods, or at least adding lash caps and checking things out... Again check with the rocker company..
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#775605
08/17/10 02:05 AM
08/17/10 02:05 AM
Von
NE Oklahoma
The rockers are bronze bushed factory adjustables, so I have no idea what the factory spec is.
Anybody know?
[Re: Big Squeeze]
#775606
08/17/10 02:08 AM
08/17/10 02:08 AM
Von
NE Oklahoma
Hey PVP......I've got a few extra sets of pushrods laying around.....Bring by what you have and we can see if I have something that'll work better........
I may take you up on that!! Ive got some rough measurements. Depending on which adjusters I use I need either 9.040 effective length or 9.140.
Got anything close?
Thanks, you big
[Re: Von]
#775607
08/17/10 02:20 AM
08/17/10 02:20 AM
Von
NE Oklahoma
BTW, by swapping adjusters (2 different sets of adjusters) I can get 1.5 threads with one set and 4.5 threads with the other set, same pushrods. Obviously the "number of threads showing out of the bottom" isnt that accurate.
Is there an optimum distance from cup to rocker, or is it "get in a ballpark measurement"?
Hope that makes sense.
[Re: Von]
#775608
08/17/10 09:56 AM
08/17/10 09:56 AM
Posts: 4,210 New York
polyspheric
New York
Leaving out any oil or interference problem: the smallest possible adjuster has the highest rocker ratio. No threads at all is best, but you need some adjustment somewhere. The actual distance from the rocker body to the adjuster ball or cup is what matters, not the threads. The number of threads is only important in that the adjuster is more likely to break. However: it may push your geometry over the cliff.
Every time someone says "use lash caps" I get a headache. I'd ask everyone who doesn't understand this to refrain from commenting - but everyone knows I'm not talking about them.....
Boffin Emeritus
[Re: bigtimeauto]
#775610
08/17/10 03:15 PM
08/17/10 03:15 PM
polyspheric
New York
Is that a question, or a statement?
Boffin Emeritus
[Re: bigtimeauto]
#775612
08/17/10 03:29 PM
08/17/10 03:29 PM
polyspheric
New York
Fine, we'll do it your way. Your first remark appears to be a question, but you followed it with a statement that pretty much says it doesn't.
It does.
your turn.
Boffin Emeritus
[Re: polyspheric]
#775613
08/17/10 04:04 PM
08/17/10 04:04 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
You want to play instead of answering my question thats fine.
"However: it may push your geometry over the cliff."
You said adjusting the rocker arm affects geometry, i asked why would you say that and asked for your reasoning.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: tboomer]
#775615
08/17/10 04:18 PM
08/17/10 04:18 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Im curious also,,,
You would be raising, lowering the adjuster, just where the pushrod makes mechanical contact with the rocker. Changing the geometry would mean you would physically move the fulcrum up, down, inn or out changine where it makes physical contact with the spring, or changing the ratio by moving the adjuster in, or out from the fulcrum.
Kasey
[Re: bigtimeauto]
#775620
08/17/10 05:37 PM
08/17/10 05:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The old direct connection book says that the ball should be 5/16 from the rocker arm.Not all adjusters are the same.I have seen it with my own eyes that when the ball is closer to the rocker;the folcum will be closer to the shaft and will lift the valve more.Its not much but it happens.
nobody is talking lift we are talking geometry
What occurs when you change the adjuster is it starts putting a lot of side load and reducing the lift.. it in i self(adjuster) doesnt change the valve/rocker geometry
