What is the rod on back of TF727?
#775506
08/16/10 10:20 PM
08/16/10 10:20 PM
Posts: 62 Chillicothe, Ohio
Groundhawg
Chillicothe, Ohio
Hi. I've got a TF727 transmission in an '87 Dodge 4x4 and it's leaking from a rod that is located right below the tailshaft on the back. The rod is flush with the casing and is right above the tranny pan. It moves slightly in and out, not sure if that's normal. I don't know the first thing about the inner workings of a transmission and I can't seem to find a pic of it anywhere. What is this rod to? How hard is it gonna be to re-seal? ![](/ubbthreads/images/graemlins/smilie_help.gif)
1987 Dodge Power Ram, 1972 440, MP .484 cam, Edel. RPM intake, Edelbrock EPS800 carb., Hedman headers, dual 3" exhuast with Flowmaster mufflers, 3" body lift, 285/75 Mickey Thompson MTX on 16x10 AE 186s
Re: What is the rod on back of TF727?
[Re: GregCon]
#775509
08/16/10 10:44 PM
08/16/10 10:44 PM
Groundhawg
Chillicothe, Ohio
Thank you guys! What is involved in removing the tailshaft? Obviously removing the transfer case but is the tailshaft simply bolted onto the back of the tranny or is there internal stuff connecting it? Does the valve body or anthing have to come out? Sorry for all the questions
[Re: Groundhawg]
#775510
08/16/10 10:52 PM
08/16/10 10:52 PM
Posts: 4,761 Florida
BDW
[Re: GregCon]
#775513
08/16/10 10:58 PM
08/16/10 10:58 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
No VB removal needed as I recall
I think the wide portion of the VB blocks access... Been a few years there may be access... If the shaft comes out to far things get more complicated.
[Re: 1_WILD_RT]
#775514
08/16/10 11:08 PM
08/16/10 11:08 PM
Groundhawg
Chillicothe, Ohio
Once again. Thanks guys. Not sure which route I'm going to go. I just replaced the front seal that was leaking on the transfer case a couple weeks ago but I thought my pan gasket was leaking also. Just found out the shaft was leaking and not the pan today. Of course I've got the transfer case back in now. I guess that's how it goes sometimes ![](/ubbthreads/images/graemlins/2491406-danstruck.gif)
[Re: GregCon]
#775516
08/16/10 11:33 PM
08/16/10 11:33 PM
Groundhawg
Chillicothe, Ohio
The transmission is originally out of a 72 Chrysler New Yorker. I had it rebuilt 4yrs ago and they swapped tailshafts in the process.
[Re: Groundhawg]
#775517
09/12/10 12:16 AM
09/12/10 12:16 AM
Groundhawg
Chillicothe, Ohio
I gooped it with the Right Stuff and so far so good. Thank you guys ![](/ubbthreads/images/graemlins/thumbs.gif)
