drive shaft yoke question #775220
08/16/10 04:33 PM
08/16/10 04:33 PM
MS, USA
K
killercoronet Offline OP
K
MS, USA
I recently went from a SB 360 to a BB 440 in my Coronet. I know i have change my slip yoke to a 7290 no question with the new 727. My question in the rear is i would like to update to a 7290 yoke at the rear but my driveshaft is 7260 (2 1/8). Has anyone ever used the mancini conversion u joint kit,and is it strong? and change my rear yoke to 7290. Or would it be ok to stay 7260 in the rear. My engine dynoed 387hp and 430 ft lbs torque. What do ya'll think.
Re: drive shaft yoke question [Re: killercoronet] #775221
08/16/10 05:20 PM
08/16/10 05:20 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: drive shaft yoke question [Re: killercoronet] #775222
08/17/10 03:50 PM
08/17/10 03:50 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
Can you just find a 727 slip yoke with the 7260 joint? I know Challengers and 340 dusters had them.
I take it your car had a 904? Is the shaft going to be to long?
Just asking to make sure what you have!
Joe Sr
Re: drive shaft yoke question [Re: killercoronet] #775223
08/17/10 04:54 PM
08/17/10 04:54 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Unles you are going to be putting out a lot of power you don't need the larger joints and yokes. For regular driving and light drag useage you will be fine with the smaller joint. The vast majority of the cars and even the 4X4 1/2 ton trucks used the smaller joints. You will however have to shorten the drive shaft from a 904 and get a 727 yoke.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: drive shaft yoke question [Re: MoparforLife] #775224
08/17/10 06:27 PM
08/17/10 06:27 PM
MS, USA
K
K
MS, USA
Ok so the rear of the shaft i get, and for the front i need to get a 7290 slip yoke, and have it shortened. what type of u joint should i get for the front, and does anyone know how much i need to get it shortened. Lengths for a 67 coronet BB w/727
Re: drive shaft yoke question [Re: killercoronet] #775225
08/17/10 07:19 PM
08/17/10 07:19 PM
Upper Midwest
Upper Midwest
Why do you feel that you need a 7290 slip yoke? Are you running a lot of power??? Like I said before most had the 7260 joints on both ends. I know a lot of 12 second and even 11 second cars running with the 7260 joints with no problems.
Re: drive shaft yoke question [Re: MoparforLife] #775226
08/17/10 07:23 PM
08/17/10 07:23 PM
MS, USA
K
K
MS, USA
the 7260 yoke that is on my old driveshaft isn't big enough to slide over the shaft on the 727 that i have now.
Re: drive shaft yoke question [Re: killercoronet] #775227
08/17/10 11:31 PM
08/17/10 11:31 PM
Upper Midwest
Upper Midwest
What you have is thew yoke for the 904 and a 904 has a smaller output shaft than the 727 output shaft. The 7260 yoke for the 727 will fit right into your transmission. Fact being it is the most common 727 yoke. Just about any yoke from a 727 will be that yoke and not the larger one.
Re: drive shaft yoke question [Re: MoparforLife] #775228
08/18/10 12:14 PM
08/18/10 12:14 PM
MS, USA
K
K
MS, USA
So judging by this pick ill need 3.89" cut out of my shaft to fit the 727? If Im wrong how much will need to be cut out? BTW you guys have been a huge help so far,Thanks
