Mancini 493 kit compression
#775178
08/16/10 03:01 PM
08/16/10 03:01 PM
Posts: 190 Communist New York State, Comi...
We The People
Anyone use the 493 dish piston kit? I just called them and asked what compression the two kits had cause its not listed?? The guy said with 75cc the flat top would be 13.1 to1 and the dish would be 12.4 to 1. this 12.4 to 1 with a dish doesnt sound right to me. why would they sell two kits that you need race fuel with? at less than one point apart. that makes no sense. diamond has a list piston #52415 that would be about 11.2 to 1 in a 72cc head that would be perfect. Did I just get more bad customer service from mancini.....seems like the status quo for them, rushing you on the phone while shopping for a 1750 dollar item WOW
Re: Mancini 493 kit compression
[Re: We The People]
#775179
08/16/10 03:05 PM
08/16/10 03:05 PM
Posts: 5,080 organ
maximum entropy
organ
mine came with diamond pistons, and at zero deck with 1009 gaskets and 84 cc chambers it measured 10.33/1. mine's .040 over, so the 493 would be a little less.
[Re: We The People]
#775183
08/16/10 04:21 PM
08/16/10 04:21 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
This is accurate data, but I did NOT use an actual piston, just generalities based on what you asked.
# of Cyl. 8 COMP. WEDGE ENGINES Bore 4.3500 Stroke 4.1500 Rod Len. 6.760 Gskt Bore 4.410 Comp. Gskt .0390 Block Deck Ht. 10.7200 Top ring down 0.260 Chamb. Vol. 75.0 Dome (-) Dish (+)5.00 Piston / deck 0.005 Total volume 1102.97 Cylinder volume 1010.69 Clearance volume 92.28 Gasket volume 9.76 Top ring volume 1.30 Deck volume 1.22 Piston top land 4.305 1/2 Stroke 2.075 Comp. Ht. 1.880 Cubic Inches 493.41 Compression ratio 11.95
With a 15.0cc dish:
# of Cyl. 8 COMP. WEDGE ENGINES Bore 4.3500 Stroke 4.1500 Rod Len. 6.760 Gskt Bore 4.410 Comp. Gskt .0390 Block Deck Ht. 10.7200 Top ring down 0.260 Chamb. Vol. 75.0 Dome (-) Dish (+) 15.00 Piston / deck 0.005 Total volume 1112.97 Cylinder volume 1010.69 Clearance volume 102.28 Gasket volume 9.76 Top ring volume 1.30 Deck volume 1.22 Piston top land 4.305 1/2 Stroke 2.075 Comp. Ht. 1.880 Cubic Inches 493.41 Compression ratio 10.88
RIP Monte Smith
[Re: We The People]
#775185
08/16/10 10:23 PM
08/16/10 10:23 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
The reason I remember is I built a similar engine a few years back. It was a RB engine deck height deck to 10.72 inch. back then there wasnt a large selection of stroker cranks with 4.15 stroke.. You had MP and then Eagle. Both were standard mopar rod pins...Anyways I used Probe pistons with a CH of 1.85 the pistons were in the hole .005-.008 inch and used Eagle 6.76 H=beam rods. Those Probe pistons have a generic -4cc valve relief, and I was using the PT replacement head gasket with Box stock Edelbrock RPM heads... Compression with the 84cc heads was 10.8-11:1 and run just fine on pump 92 gas.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
