how the BLEEP do you take a distributor apart??? #774497
08/15/10 10:18 PM
08/15/10 10:18 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
i have an electronic 440 dist and i want to change the advance springs. i have a FSM and it doesn't say how to pull the part with the slots. there is a "snap ring" type of wire retainer that is accessed from the top and i can't get it off how do i disassemble to change advance springs or weld up slots. that little clip has me by the short and curlys right now. any tips or tricks?? i had to walk away from it before hurling it across the room
Re: how the BLEEP do you take a distributor apart??? [Re: dirtybee] #774498
08/15/10 10:34 PM
08/15/10 10:34 PM
Sioux Falls,South Dakota
fouronthefloor77 Offline
I've always been able to pry the clip out with a needle nosed pliers
Re: how the BLEEP do you take a distributor apart??? [Re: fouronthefloor77] #774499
08/15/10 10:48 PM
08/15/10 10:48 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
so do you just grab one of the prongs and try and pull it out while wiggling or do you spread them open with the pliers. mine just kept slipping off and now i want to smash something.
Re: how the BLEEP do you take a distributor apart??? [Re: dirtybee] #774500
08/15/10 10:48 PM
08/15/10 10:48 PM
Clamp the dist w padding securely in your vise vertical & take your long thin needle nose pliers and stick it in there in between the 2 vertical legs and spread them apart. You wont be able to spread them more than a very slight bit but that will be enough. Do it several times. Then grab one of the vertical legs w your pliers and whip it AROUND to it's open side (eyeball to see which way to go) & UP in the same motion. Note which hole the roll pin is in for reassembly. A good idea is to press the center shaft down lightly w your thumb as a helper levers the reluctor up w a pair of screwdrivers opposite of each other and after you get it up some then switch to a pair of tire irons and continue to lever it up (EVENLY). I wash everything w solvent/blow it dry & lube the parts that need to be lubed w silicone lube and the spray on dry lube may be even better. Drive out the roll pin on the bottom shaft/take off the collar and add flat washers until the end play is ALMOST zero. When your back together take the clip and straighten the 2 legs and the circular base as it will be slightly deformed and drop it in on top of the nub and w a pair of mini screwdrivers opposite each other push the circular wire base down over the nub then use your needle nose's to compress the 2 legs together. Same as before you wont move it much but it'll be enough to get at least some of the base circle under the nub which is good enough to secure it. I like to set the reluctor on the shaft barely w your initial set on the balancer and see if using the other (roll pin) will give me better phasing and note that only the vac adv will change the phasing in use (moves it CW on a BB and CCW on a SB). Caveat, always press down on the center shaft anytime you are pulling the reluctor up as some dizzys have enough tolerance that the weights will come off of the pins before you have it apart and you dont want to deal w that.
Re: how the BLEEP do you take a distributor apart??? [Re: dirtybee] #774501
08/15/10 10:50 PM
08/15/10 10:50 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
small needle nose pliers
Re: how the BLEEP do you take a distributor apart??? [Re: RapidRobert] #774502
08/15/10 11:17 PM
08/15/10 11:17 PM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
holy smokes rapid, thanks man i'm going to try that first thing or maybe later tonight. i've said this before but i'll say it again, you really help whenever people have tech questions. thank you,
Re: how the BLEEP do you take a distributor apart??? [Re: dirtybee] #774503
08/16/10 01:16 AM
08/16/10 01:16 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
DONE! thanks again
Re: how the BLEEP do you take a distributor apart??? [Re: RapidRobert] #774504
08/16/10 03:02 PM
08/16/10 03:02 PM
PA
moparboy66 Offline
moparboy66  Offline
PA
Robert, you make everything doable and every problem solvable. Thanks as always.
Re: how the BLEEP do you take a distributor apart??? [Re: moparboy66] #774505
08/16/10 03:07 PM
08/16/10 03:07 PM
Andrewh Offline
Andrewh  Offline
tech archive this thread please.
