Re: Valve cover baffle alternative?
[Re: topside]
#774154
08/15/10 03:05 PM
08/15/10 03:05 PM
Posts: 20,736 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I have an old set of finned edelbrock aluminum covers on my truck and to keep the oil from going out the K&N valve cover breather I built an extension out of steel tubing that raises the breather up about 6" off the top of the cover. It looks sorta like a circletrack or trans-am setup.... http://www.sallee-chevrolet.com/ChevySmallBlockV8s/images/88958602.jpgI think you can buy pcv valves that have shields built around them that function like a baffle.
[Re: 65Sat440]
#774165
08/15/10 10:53 PM
08/15/10 10:53 PM
Posts: 8,907 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Scroll down to the second image. Those are grommets and baffles, dude!
A-HA !! Can't see 'em working on a Mopar (the brand "Moroso" should explain what they're meant for) - I doubt they'll clear the rocker shaft or rockers or springs.
