Re: SB Alternator bracket for a Meziere water pump.
[Re: LA360]
#774100
09/01/10 10:46 AM
09/01/10 10:46 AM
Posts: 12,478 Taxes & Virus's R-US, NY
Dragula
I am going to order one, my pump showed up, I also need a 3/4npt block off plug. Called, and no answer. I will try later, but I might have a work around plan in place where I don't need one.
[Re: Dragula]
#774101
09/01/10 11:58 AM
09/01/10 11:58 AM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
When I called I left a message and he called me back pretty quick.
68 Barracuda Formula S 340
[Re: Dragula]
#774103
09/05/10 12:41 AM
09/05/10 12:41 AM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Did your brackets show up? I really wish I could have helped Bob put together a more finished kit, with the lower crank pulley, spacers, alternator and even a belt and the bolts. Not having that stuff kinda makes for a hell of a time getting it all together and finished. Hope it works out well for you guys.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#774104
09/05/10 01:01 AM
09/05/10 01:01 AM
Dragula
I did get mine, but because I bought a Proform water pump from mancini, as well as one of their smaller alternators, nothing fit. Luckily, I have become rather acustomed to doing a lot of fabricating to get things to work on all my darn cars/trucks. I made the spacers at work, and used the slider that allows you to adjust the tension on the belt from the mancini kit. I am affraid though, there isn't much left of the bracket I recieved, but it did help.
[Re: Dragula]
#774105
09/05/10 01:30 AM
09/05/10 01:30 AM
Bad340fish
Tulsa OK
Mine came within 4 days of ordering it. It will be a month or so before I get to try it out but I am not worried about having to adapt anything. Its lightyears nicer than the bracket I was using. That bracket was so bad I tossed it when I pulled the motor so I wouldn't be tempted to use it again.
[Re: PUNK]
#774106
10/28/10 08:50 PM
10/28/10 08:50 PM
Bad340fish
Tulsa OK
Got mine installed today. It uses a delco cs130 alternator I got one from a 91 Buick century it's 105 amps and looks exactly like the powermaster pictured with the bracket. It took 3 wires to hook up and works great. 14.4 volts at idle with a 5 inch crank pulley running msd, elec fan, water pump, and fuel pump. I will post a picture in a few minutes.
[Re: Bad340fish]
#774107
10/28/10 09:19 PM
10/28/10 09:19 PM
Posts: 21,066 in a cattle trailer down by th...
Guitar Jones
I made my own using a Denso alternator off a Bobcat. Not a great pic but you get the idea.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#774108
10/28/10 09:39 PM
10/28/10 09:39 PM
Bad340fish
Tulsa OK
Here is a picture. I didn't have to use a spacer on the crank pulley but I believe its from the fluid dampner bieng thicker than a stock piece, if it wasn't it would have needed a spacer for sure. Thanks Sloan/Punk for pushing this through its alot nicer than I could have produced for sure. This was the finishing touches on my electrical system remodel. I eliminated the ameter and all factory wiring that didn't have to do with lights or wipers. My starter relay is in the trunk with the battery now also. Sure cleans up stuff under the hood. My wiring before looked like the scrap bin at an electrical supply! I got lots of ideas of of this site so thanks to those that contribute there projects on here. Clark
[Re: 340_Dart]
#774110
10/28/10 10:09 PM
10/28/10 10:09 PM
Guitar Jones
