Front Power disk ... WILL NOT BLEED
#773924
08/15/10 12:51 AM
08/15/10 12:51 AM
Posts: 267 Santa Clara , ca
ramcuda
Santa Clara , ca
ok 1970 superbird .... I put all new breaks in it as in new lines new valves all 3 .... new rear wheel cyc new front calipers new rubber lines ...
only thing not new was the booster and rotors ...
ok the back bleeds out ok ..
for the last 2 months i have been trying to get the fronts to bleed out ...
the peddle only goes down about 1in i bottle bleed the front and i get only a trickle out of the calipers .. same both sides ...
when the peddle is pumped it doesnt have any fluid pressure ..
I have gone threw all the lines in front even the dam "Texas" valve and it works like the book says,,
Now the book all so states that if you peddle bleed you dont need to hold the valve open ...
all thow the book tell you to PUSH IN the valve.. but you need to pull on it to open it ...
i have tryed many ways and no front breaks ,,,
HELP !!!!!!!!
1965 Ply "RAMCUDA" got to see it!!!<--- Should sell it/ 1970 Superbird <------ Just one big argument/ 1980 Jeep CJ5 <--- Just wheel it/ 2000 Dakota R/T <--- Should Drive it more/ 2001 Dodge Caravan <----- Cant kill it/ 2004 Dodge 2500 4dr DIZLE 4x4 <---- LOVE IT !!! www.moparalley.org
Re: Front Power disk ... WILL NOT BLEED
[Re: ph23vo]
#773926
08/15/10 01:06 AM
08/15/10 01:06 AM
ramcuda
Santa Clara , ca
thats not it ...
I put the 2nd new master in it to day ... bench bleed great ,,,
[Re: ph23vo]
#773928
08/15/10 01:40 AM
08/15/10 01:40 AM
ramcuda
Santa Clara , ca
Thanks tryed that to ...
when pulled off the factory master the end of the rod was a few threads out ... and i tryed the new master's and things didnt work...
So now i read up on that adjustment so i try with the end of the rod all the way in .. and no change
after two months of this ... i think i have tryed anything and ever thing
[Re: ramcuda]
#773930
08/15/10 02:24 AM
08/15/10 02:24 AM
Posts: 415 Indiana
Pentastar440
Indiana
If the calipers are mounted on the wrong side the bleeders will be at the bottom and not at the top where they should be.
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
[Re: Pentastar440]
#773931
08/15/10 04:56 AM
08/15/10 04:56 AM
ramcuda
Santa Clara , ca
wagon @ pent440
yes i made sure the p-valve was clean and centered
and the bleeders are on top ...
I think its the little disk valve ( see pic ) I dont know alot about it...or how it works ..does it hold presser back in the front ? the book tells me it opens at 135psi.. it opens when the peddle is pushed i can see it working..
Mind you thes valves and lines are all new from inline ... and i know new doesnt always = working ....
[Re: ramcuda]
#773932
08/15/10 05:04 AM
08/15/10 05:04 AM
RapidRobert
grab that little pin w a pair of vice grips & pull on it/hold it so it stays "out", then bleed
[Re: RapidRobert]
#773933
08/15/10 05:28 AM
08/15/10 05:28 AM
ramcuda
Santa Clara , ca
ok sorry for the big pic ,,,
Rob we have done that as well and nothing ...
next two pic is what the book tells me ... Now i know you cant push it in ... but if you did hold it in it would not pass fluid
[Re: ramcuda]
#773934
08/15/10 05:33 AM
08/15/10 05:33 AM
ramcuda
Santa Clara , ca
[Re: ahy]
#773936
08/16/10 01:21 AM
08/16/10 01:21 AM
ramcuda
Santa Clara , ca
thanks Ahy..
I was going to do just that .. its the only to prove the part bad ...
as far as i know it just a kinda safety valve to improve breaking ...
David
[Re: ramcuda]
#773937
08/16/10 02:49 PM
08/16/10 02:49 PM
Posts: 1,145 ontario calif
ns1aar
ontario calif
I'v had a prob valve get pushed all the way to one side with the same results
NS1AAR
[Re: 1969RR]
#773939
08/16/10 09:54 PM
08/16/10 09:54 PM
ramcuda
Santa Clara , ca
didnt make to the pick up the brass T today .. today i did talk to the guy at a shop that rebuilds boosters and master cyc.. he told me i need to make sure that the piston in the master cyc is returning all the way .. the adjustable end on the rod that comes out of the booster. I had to remove it so there was room for cyc to fully return.. now i have a better peddle.. but still the no fluid threw the fronts.. I called in-line tube and they had idea.. Tomorrow im going to swap in a valve set from a 71 E-Body and see .. HERE IS A PIC OF MY SETUP
[Re: Paul Jacobs]
#773941
08/16/10 10:52 PM
08/16/10 10:52 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Your problem is the Inline Tube valves-they are bad. There has been a rash of them and everyone is having problems with them! I am speaking from experience. Get some from Fine Lines and your problem will be solved.
....Paul, I read all the way thru this post to see that you beat me to the "punch" ...after I read "Inline tube" valves,...I thought there's his problem,...I've said it time and time again,...Inline is cheap junk,...Finelines is the only quality brake product on the market, more money, but you get what you pay for
Mike
[Re: DAYCLONA]
#773942
08/17/10 02:23 AM
08/17/10 02:23 AM
ramcuda
Santa Clara , ca
well i did call fine lines first they had all the lines and the guy on the phone told me that they did have all the valves i needed .. i even asked him to go look to be sure and he came back on the line told me that they did so i payed the man.. (i was going to have the car at MATS if they did).. i even asked him about the falling out with inline .. as fine lines used to supply inline with valves... so a week later still no box on my door . so i called fine and got Mike and he told me that they didnt have the valves and his guy should not had said that ..he said he go see what he could do and will call me back .. So in a pinch i called in line and they had every thing ... I called and Mike back on the phone the next day and killed my order.. Trust me Fine was my first stop ... if i was not trying to make a dead line i would have wated... and tomorrow if i put in the OE parts in and it works im going to have a $^#@%&
