Comp Cams XE275HL with Stock 452 Heads?
#773526
08/14/10 12:16 PM
08/14/10 12:16 PM
Posts: 115 Tampa Bay
BadFishy
Tampa Bay
Hello, I want to add some oomph to my 440. Will this cam work with bone stock heads & valve train (other than a 3 angle valve job)? Or will I have to do some mods to the heads anywhere, such as springs, etc. I am trying to avoid machining or new heads, etc. I am looking for guidance on the fitment, clearance, etc, not carb, headers, axle, converter, etc. Thanks in advance.
1971 Cuda, 440 custom-build
Re: Comp Cams XE275HL with Stock 452 Heads?
[Re: BadFishy]
#773527
08/14/10 12:33 PM
08/14/10 12:33 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
if your compression is decent, it'll do fine. mine was zero deck, around 9.5:1 comp with stock 906 heads, and it felt like an honest 450 hp, with lots of low end torque...easilly spun the tires from a 20 mph roll with 3.21 gears.
I swapped to eddy heads, closed chambers... which sent me to about 10.5:1 and went to an engine dyno, made a solid 500 lbs of torque through the RPM curve.
**Photobucket sucks**
[Re: R/T1968R/T]
#773530
08/14/10 07:35 PM
08/14/10 07:35 PM
BadFishy
Tampa Bay
Thanks guys, that is what I needed to know.
