Electric fuel pump saftey question
#773361
08/14/10 09:09 AM
08/14/10 09:09 AM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
I installed an electric fuel pump over a year ago. I like it. Car starts better & I ugraded the fuel line & installed a regulator at the same time. However I have always been worried about if it continues to run if I where to crash or have a major engine problem. Causing a fire. I see Summit & Jegs sell a fuel psi cut off switch that looks like it T's into the oil psi switch. So when oil psi drops it will shut down the fuel pump. So then do you need to put it on a toggle switch also so you can cut the fuel pump on to start the car. Or just let the engine spin over untill it has enough oil psi to override the saftey switch. Whats the proper way to address this problem on a mild bracket car?
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
Re: Electric fuel pump saftey question
[Re: rockerbob]
#773362
08/14/10 10:32 AM
08/14/10 10:32 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you dont like cranking it put the switch on it (also if its slow building oil pressure) but otherwise just run the low oil pressure switch to a relay then to the pump.... most of us dont even run the low pressure switch unless its hooked up to the ignition to kill the engine on a low oil pressure condition but again alot of us have a master kill switch... JMO
[Re: MR_P_BODY]
#773363
08/14/10 10:49 AM
08/14/10 10:49 AM
rockerbob
Raleigh, NC
Mr P, thanks for the reply, but dumb question. What would the relay do? Also I bought a Moroso master cutoff, just haven't installed it yet.
I have seen a few crashes especially on the TNT nights when the crazies come out with their 600 HP street cars & blow the tires off & smack the wall. It takes a while before a track worker can get to them sometimes even if they did have a master cutoff.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
[Re: rockerbob]
#773365
08/14/10 10:56 AM
08/14/10 10:56 AM
MR_P_BODY
The relay is to carry the load of the pump... that little low oil pressure switch cant carry the load of the pump so you need to run a relay... you just run the low pressure switch wire to turn on the relay
[Re: Devilbrad]
#773367
08/14/10 11:12 AM
08/14/10 11:12 AM
MR_P_BODY
Ford originally used these inertia activated fuel cut off switches in their cars and trucks. they have since been adapted to road race cars. We installed them in all the Porsches at my old shop. They work real good! http://www.smartracingproducts.com/catalog/electrical.htm
Chrysler used a shut off like that back when we first started using injection but since dropped them
[Re: MR_P_BODY]
#773368
08/14/10 11:15 AM
08/14/10 11:15 AM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
I was unaware of that. The only draw back I have seen with these switches was big pot holes and blown out tires on production cars. They can and will trip the switches, LOL "I got a flat tire and now my car won't start!"
[Re: MR_P_BODY]
#773370
08/14/10 01:07 PM
08/14/10 01:07 PM
rockerbob
Raleigh, NC
Thanks everyone I am better educated now. I think I will try to get the master cutoff installed today. Fred that inside switch looks like a neat deal. I'll look into that.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
